ᐅ How can I assemble my Pax wardrobe in a space-saving way?
Created on: 17 Jun 2021 19:07
alessand36A
alessand3617 Jun 2021 19:07Hello everyone,
I am currently planning to set up my Pax wardrobe from Ikea in my somewhat small apartment in the most space-saving way possible. Since I don’t have much room for large, bulky furniture, I want to avoid my wardrobe taking up unnecessary floor space while still providing as much storage capacity as possible and being well organized.
My questions are:
- Which assembly options for the Pax system help to use the available space most efficiently?
- Are there any experiences or tips on how to optimize the interior design (drawers, clothes rails, shelves) to make the best use of the wardrobe space?
- Would it be better to use several narrower Pax units instead of one large one?
- And what about the depth of the wardrobes – is it worthwhile to choose shallower models to improve the room’s overall feel?
I look forward to your suggestions and experiences, especially if you know of creative solutions that aren’t immediately obvious. Thanks in advance!
My questions are:
Hello alessand36,
to set up your Pax wardrobe in a space-saving way, you should consider the following points:
- Cabinets in narrower widths (50-75 cm [20-30 inches]) are advantageous in small rooms because they take up less floor space and fit better into niches.
- Instead of the "standard" depth of 58 cm (23 inches), you can use the shallower versions with a depth of 35 cm (14 inches) to allow more room for movement. However, these are somewhat limited, for example, when hanging wider clothing.
- The interior organization should be modular:
- Many drawers and baskets allow for better division compared to only clothes rails.
- Adjustable shelves can be adapted as needed.
- If possible, you can also use corner cabinets with hinged or sliding doors to make better use of corner space.
I recommend starting with an accurate room measurement and a drawing that you compare with the Ikea planner. This will help you avoid purchasing mistakes.
In summary: several smaller and rather shallower Pax units with flexible interior elements help to use the space optimally.
BEMAU schrieb:
The interior fittings should be chosen modularly:
- Many drawers and baskets allow for better organization instead of just hanging rods.I would like to add this: Especially in small rooms, a clear interior layout is important to make the most of the space.
I have fitted my Pax wardrobe modularly with drawers, adjustable shelves, and pull-outs. This makes using it much more flexible. I also recommend, if possible, installing sliding doors. Compared to regular doors, they save space when opened, which is very valuable in tight rooms.
Regarding depth: 35 cm (14 inches) depth is ideal for pants, tops, and smaller clothing items, but for coats or bulky jackets, a depth of 58 cm (23 inches) is better.
Finally, a tip: Some people use hanging rods only for longer clothing and place shorter items on shelves – this also saves space. When planning, consider what you usually want to access quickly and how.
If you like, I can also prepare a list of recommended interior fittings that have worked well for me.
alessand36 schrieb:
My questions are:
- Are there any experiences or tips on how to optimize closet space by choosing interior fittings such as drawers, hanging rods, or shelves?
- And what about the depth of the wardrobes – is it worthwhile to choose shallower models to improve the sense of space?Regarding your comprehensive questions, here are some points I can confirm from my own installation projects:
1. Multiple narrower modules allow more flexible adaptation to room shapes and enable individual interior fittings per unit – this increases space utilization.
2. Shallower Pax units (35 cm depth) are especially recommended in smaller rooms. The reduced depth provides more walking space in the room.
3. Interior elements like drawers and shelving systems improve organization and make it easier to use, as you can store and see everything without having to rearrange.
4. Combining hanging rods for long garments in one module and drawers/baskets for smaller clothing items in another offers a good balance.
Conclusion: For small spaces, a divided setup with a shallower profile and well-thought-out interior fittings is definitely worth it.
I also recommend choosing soft-close doors if you need a lot of free movement, so that nothing gets awkwardly in the way.
