ᐅ How can I assemble and use IKEA Metod cabinets with minimal noise?
Created on: 6 Apr 2021 08:43
ianfa
ianfa
6 Apr 2021 08:43
I would like to raise the question in this thread: How can IKEA Metod kitchen and storage cabinets be assembled and used quietly? From my experience, cabinet doors and drawers often rattle or squeak during assembly and especially in daily use, which I find annoying. What exactly causes this? What assembly steps or adjustments can I make to reduce the noise of the cabinets? Are there any special tools, accessories, or perhaps dampers that should be used additionally? I am also interested in whether there are certain precautions I can take in everyday use to keep the noise level as low as possible. I look forward to well-founded tips and practical advice that go beyond simply putting the cabinets together.
RENMA
6 Apr 2021 09:26
ianfa schrieb:
How can I assemble and use IKEA Metod kitchen and storage cabinets to minimize noise?
Metod cabinets generally use a standardized assembly system where the correct use of the included damping components and screws is crucial. The following points are essential:
- Check that all screws and fasteners are securely tightened, as loose screws can cause rattling noises.
- Use soft-close hinges for doors if they are not already installed; these significantly reduce slamming sounds.
- Installation aids such as silicone or rubber washers beneath screws can help reduce vibrations.
- Drawers must be precisely fitted; adjusting them can prevent scraping noises.
In daily use, noise can be further minimized by closing doors and drawers gently and avoiding overloading. Additional accessories like extra dampers have limited compatibility but can be useful if needed.
LOSAR
6 Apr 2021 09:58
Always replace door hinges at IKEA with soft-close versions. Tighten screws securely, but avoid excessive load. Simply adjust the drawers properly.
blapau
6 Apr 2021 10:34
RENMA schrieb:
In particular, use soft-close door hinges if you haven’t already; they significantly reduce slamming.
I would like to add: When installing, make sure the mounting surface is perfectly level. Unevenness can cause stress that increases noise through the hinges and cabinet frames. It is also recommended to align all doors synchronously at the end so they close smoothly and simultaneously. This helps prevent unpleasant after-swinging.
tanru
7 Apr 2021 14:03
I understand the recommendations regarding soft-close mechanisms and even screwing, but I would like to point out critically that these are almost obvious and well-known. I would find concrete experiences with alternative dampers or modifications—beyond what is typically offered by IKEA—much more interesting.
Even with soft-close, some users report noises due to changes in humidity or extreme temperature conditions in the kitchen. Has anyone investigated to what extent additional insulation materials in cavities or between the cabinet and the wall provide a significant improvement?
It would also be helpful to know whether all these measures really have a long-term effect, or if the noise returns after a few months. Who has long-term experience?
putan
7 Apr 2021 18:07
tanru schrieb:
I would be more interested in concrete experiences with alternative dampers or modifications not directly from IKEA.
I can shed some light on that: I once attached felt pads to the inside edges of the doors – this really reduces all the banging and rattling. Along with the classic silicone spray on hinges and tracks, it makes a noticeable difference.
It sounds simple at first, but in the kitchen, small tricks like these can prevent a cabinet noise from interrupting your kitchen symphony. And yes, the same applies here: close gently!
I would also like to add that I haven’t noticed any long-term loss in functionality so far; the modifications have remained stable.
