ᐅ How can I adjust Billy doors if they do not close properly?
Created on: 6 Aug 2020 18:37
MEOBA9
MEOBA9
6 Aug 2020 18:37
Hello everyone, I noticed that the doors on my Billy shelf sometimes don’t close properly. Specifically, one side of the door sags slightly, causing an uneven gap between the door and the cabinet. I suspect that I need to adjust the doors to realign the hinges. Does anyone have a detailed guide or tips on how to fine-tune the Billy doors so they close neatly again? Which screws should be adjusted and in what order, and are there any special tricks to ensure the doors not only fit well but also close smoothly over time? Thanks in advance!
chenfi
6 Aug 2020 19:05
It is best to slightly loosen the two screws of the hinge on the inside, adjust the door, and then tighten them again. Afterwards, you can often turn the small screw for fine adjustment to optimize the gap to the cabinet.
refinar
7 Aug 2020 08:41
I’m happy to provide a more detailed guide to help you properly adjust your Billy doors:
1. Check the outer edge: First, verify that the cabinet itself is still straight and not warped. A twisted cabinet can also cause the doors to sit unevenly.
2. Remove the door: Fully open the door and loosen the large screws that secure the hinge to the cabinet.
3. Realign the door: Hold the door in the optimal position and tighten the screws again. This will essentially fix the door in place.
4. Fine adjustment: Billy hinges usually have an additional screw that allows you to shift the door horizontally. This is used to precisely adjust the gap between the door and the cabinet.
5. Vertical alignment: If the door sticks or rubs, you can also adjust the vertical position by using the adjustable hinge screws. These are usually smaller and located on the hinge.
6. Check the closing force: Sometimes the spring inside the hinges may be stiff or bent. If the door is aligned but still closes poorly, it’s worth checking the hinge or lightly lubricating it.
Summary: Align the door, adjust the large screws, then fine-tune the gap with the adjustment screw. It’s important to work step by step and observe the effect of each screw turn.
Common mistakes include loosening only one screw and shifting the door unevenly or not checking the cabinet for stability. If you keep these points in mind, you have a good chance of achieving a clean result.
U
usbla
7 Aug 2020 10:17
refinar schrieb:
1. Check the outer edge: First, verify that the cabinet itself is still standing straight
This step is often overlooked. For Billy bookcases, it is crucial that the cabinet is placed on a level surface and as vertically aligned as possible, since the door hinge mounting system allows only limited adjustment.
Additionally, I recommend, if possible, tightening the hinges with a metric hex key, as firmly securing the screws is important to prevent shifting. If the hinges are slightly bent, replacement should be considered, as adjustments will then be difficult.
One more tip: The middle and top hinges usually handle different loads, so precise adjustment there leads to more stable closing behavior. Check the IKEA assembly manual for details, as it explains the arrangement of the screws well.
MEOBA9
8 Aug 2020 09:50
usbla schrieb:
Middle and top hinges usually carry different loads
Thank you for the advice, I wasn’t aware of that. If I understand correctly, I should pay special attention to the top hinge if the door sticks or binds at the top edge.
One more question regarding fine adjustment: Is there a recommended order for adjusting the horizontal position of the hinges? Or would it make sense to slightly adjust both at the same time until the gap is even?
Also, how can I prevent the door from shifting again through regular use after adjustment? Should the screws be tightened particularly firmly, or are there long-term solutions to reduce the need for frequent readjustment?
