I’m currently considering whether anyone here has ever applied a high-quality vinyl wrap to their KALLAX shelf from IKEA. I’m especially interested in how suitable the material is for this, which types of vinyl work best, and how complex the process was.
I want to enhance the look of the shelf while also protecting it. I’m thinking of vinyl with a premium appearance, such as satin or even textured finishes, not just basic furniture vinyl from a hardware store.
Do you have any tips regarding manufacturers, required tools, or tricks based on your own experience?
Are there any special considerations when working with the KALLAX material to ensure the vinyl lasts long and no bubbles form?
I look forward to your experiences and recommendations!
baupar54 schrieb:
I’m especially interested in how suitable the material is for this, which films work best, and how complex the process was.Hello! I covered my KALLAX about a year ago with a matte outdoor film – wanted something more durable and I’m very satisfied. The surface is relatively smooth, which makes applying the film easier.
The effort? Not too bad at all. If you take your time and use a squeegee, almost nothing can go wrong. I even used a hairdryer a bit to help press the film better onto the shelf and get rid of small bubbles.
baupar54 schrieb:
I want to improve the look of the shelf but also protect it.That works great, and the film also gives the shelf a somewhat higher-quality feel. Plus, you can easily change it later since the film usually comes off quite well.
Leonardteo1 Oct 2021 08:22Hello,
I fully agree with meGreg, but I would like to add a caution specifically regarding IKEA furniture with melamine-coated surfaces.
The KALLAX often has a slightly porous texture or surface structure that can make perfectly smooth adhesion difficult. I recommend high-quality self-adhesive furniture films from brands like Oracal or Avery—especially those designed for furniture and interior use.
Important: Clean the surface thoroughly with isopropanol to remove any grease or dust particles. I also suggest storing the film at room temperature beforehand, as this improves its flexibility during application.
If you have large areas to cover, it’s best to work in strips and carefully smooth down the film to ensure good adhesion and avoid air bubbles.
Leonardteo schrieb:
The KALLAX is often slightly porous or has a texture that can make achieving a completely smooth adhesion difficult.That’s exactly the challenge with applying film, which I’ve also experienced firsthand.
Additionally, I would recommend testing a small, inconspicuous area before working on a large surface. This way, you can find out how well the film adheres and whether you might need a primer.
And very important: work slowly and patiently! The first time I rushed a bit and ended up with wrinkles at the edges. The second time, taking my time made a significant difference.
If you’re worried about scratches or similar issues – a film wrap provides exactly that kind of protection, especially with textured or matte films.
Ramon4 schrieb:
The first time, I was quite nervous and ended up with wrinkles on the edges.I know that feeling all too well! One technique that helped me was cutting the membrane at the corners before pressing it down. This makes it easier to lay the membrane around corners without causing wrinkles. :-)
Also, a squeegee is your best friend – I got myself one with a silicone coating back then.
For those who want a more upscale look: there are membranes with textures, like linen or even wood grain, which give the KALLAX a really stylish finish.
If anyone is looking for specific color tips or online stores, I’d be happy to share some links!
