I’m currently facing the challenge of hanging the doors on my new Ikea Metod kitchen cabinet and wanted to ask here for tips or best practices. Specifically: What is the most effective order and technique for the hinges to ensure the doors are installed cleanly and fit precisely?
I’m asking in detail because I have some experience with furniture assembly, but the doors and hinges on the Metod system are a bit confusing to me. I’m especially interested in whether it’s better to use certain adjustment options when hanging the door or if there are tricks that make aligning the doors easier – particularly concerning the evenness of the gaps.
Thanks in advance to everyone who shares their advice!
Hello Deo44,
I’m glad you’re starting the assembly of the Metod cabinet! I imagine the process can be a bit tricky, especially because of the hinges that Ikea often uses. Basically, I recommend the following approach:
- First, attach the hinges completely to the cabinet frame, not to the door.
- Then, loosely place the doors onto the hinge arms – usually, there is a clip mechanism for this.
- Now you can adjust the door using the adjustment screws: height alignment, depth, and side spacing.
- Use a spirit level or a ruler to check the gap measurements on all sides.
It’s important not to tighten all the screws immediately, but to adjust step by step and check in between. This way, you can compensate for any unevenness and still fine-tune the doors after a few days if needed.
If you have the soft-close feature, it’s also good to make some fine adjustments there so the door closes smoothly.
If you have any more questions, I’m happy to help!
For the precise installation of Ikea Metod cabinet doors, I recommend the following structured approach:
- Fully attach the hinges to the cabinet frame first, as this provides a stable base.
- Hang the door using the mounting hinge arms, initially just clipping it in lightly.
- Check the initial rough positioning.
- Then carefully adjust the three screws:
- Height adjustment (vertical)
- Side adjustment (horizontal)
- Depth adjustment (for proper door closing)
Gap widths between the door and cabinet sides, as well as between double doors, must be consistent.
I suggest using a measuring gauge or a piece of cardboard as a spacer for the gaps to ensure even alignment.
In general, the hinges of the Metod system are designed for quick readjustment afterward, which is why it’s best to tighten everything only after the final alignment.
If the doors are not sitting flush, adjusting the depth is often helpful.
This method achieves precise results without the need for rework.
KARJU schrieb:
If the doors are not fitting flush, adjusting the depth setting often helps.Exactly, the depth adjustment is often the underestimated factor! I always recommend fixing the height and the lateral alignment first, and only then experimenting with the depth adjustment. This prevents the door from shifting while you are adjusting the depth.
Also: When installing the door on both sides, patience is worthwhile, as the adjustment can take some time.
Thanks in advance for the helpful answers!
One more question: I’ve read that you can either “clip the doors in from above” or partially attach the hinges to the door before hanging it on the cabinet frame. Does anyone have experience with which method is more practical?
Also, especially with double doors: how do you handle the gap between the two doors? Is there a recommended standard gap, or is it more of an individual adjustment based on aesthetics?
The fine-tuning with cardboard as a spacer sounds good – I’ll give that a try.
