I’m currently facing the challenge of hanging the doors on my new Ikea Metod kitchen cabinet and wanted to ask here for tips or best practices. Specifically: What is the most effective order and technique for the hinges to ensure the doors are installed cleanly and fit precisely?
I’m asking in detail because I have some experience with furniture assembly, but the doors and hinges on the Metod system are a bit confusing to me. I’m especially interested in whether it’s better to use certain adjustment options when hanging the door or if there are tricks that make aligning the doors easier – particularly concerning the evenness of the gaps.
Thanks in advance to everyone who shares their advice!
Deo44 schrieb:
Does anyone have experience with what is more practical?I always attach the hinges fully to the cabinet frame first. Clipping the door onto the completed hinge arms is easier and avoids handling loose hinges on the door.
Regarding the gap between double doors:
- Ikea recommends about 2 to 3 millimeters (about 0.08 to 0.12 inches), depending on the door width.
- Visual alignment, meaning an even gap at the top, bottom, and middle, is more important than exact measurements to the millimeter.
If the gap is too wide or too narrow, it quickly looks untidy. That’s why it’s better to make small adjustments until it looks right to the eye.
I need to question the common opinion: a 2-3 mm (0.08-0.12 inch) gap for double doors might be the Ikea standard, but it’s not really ideal. I often see how such minimal gaps hardly allow any air circulation, for example, to accommodate potential expansion due to moisture.
For a durable and functional installation, I recommend a gap of 4-5 mm (0.16-0.20 inch) so that nothing gets stuck and the doors don’t rub against each other – especially with solid wood fronts.
With Metod, where the doors are usually lighter and the materials quite stable, it’s probably less critical, but I think a bit more clearance helps in the long run.
Just my provocative thesis ;-)
karlau schrieb:
I have to question the standard opinions: a 2-3 mm (0.08-0.12 inch) gap on double doors might be Ikea standard, but it’s not really ideal.Interesting point you raise. I was also considering playing it safe with a bit more clearance. Do you think this has a strong impact on the visual appearance?
Especially with the soft-close function: Could a larger gap affect the closing mechanism?
I’d appreciate more insights, since the look is important, but of course the function is as well.
