ᐅ Floor plan of a single-family house, approximately 200 sqm, without a basement, in Bauhaus style
Created on: 20 Apr 2024 07:55
2
2024_Häuslebau
Hello everyone, we are in the initial stages of planning our house. I am not yet satisfied with the current floor plan for various reasons. I believe the living space can be used much more effectively and efficiently. I look forward to your suggestions and ideas:
Plot size: 754 sqm (8,120 sq ft)
Slope: 1 m (3 ft) height difference
Site coverage ratio: 0.3
Floor area ratio: 0.6
Building envelope, building line and boundary: 10.5 x 15.5 m (34 x 51 ft) (pure building footprint due to planned attic)
Edge development
Number of parking spaces
Number of floors: 2
Roof type: flat roof
Architectural style: Bauhaus
Orientation: south
Maximum heights / limits:
Additional requirements
Homeowners’ Requirements
Style, roof type, building type: clean lines, modern
Basement, floors: no
Number of occupants, age: 37, 3-4 persons
Space requirement on ground floor and upper floor: approx. 200 sqm (2,150 sq ft)
Office: family use or home office? 2 offices, one also serving as a guest room
Number of overnight guests per year: approx. 10
Conservative or modern construction style: modern
Open kitchen, kitchen island: open, kitchen island
Number of dining seats: at least 6
Garage, carport: attic planned
Additional wishes / special features / daily routine, and reasons for why certain things should or should not be included: open space (void), 2 offices requested, sufficient storage since no basement is planned, large entrance hallway
Planning by:
- Designer from a construction company
What do you particularly like? Why? All room wishes have been fulfilled, open space in a good position with large windows
What do you dislike? Why? Corridor too long, cloakroom too far from the entrance, terrace access only around the corner behind the dining area (but there are two large sliding doors there), utility room without a window, kitchen only accessible through the living room, planned swap of utility room with guest room, little storage space in the living room
Price estimate according to architect/designer: $630,000
Preferred heating system: air-to-water heat pump
If you had to give up, which details/extensions
- can you give up: straight staircase
- cannot give up: 2 offices
Why was the design made the way it is now?
All room requirements were fulfilled but the layout is not yet optimal. Modern look (especially the southwest house corner)
Lots of wasted space, long corridors, uneven room sizes, limited storage in the living room, blocked access to the terrace
Edge development
Number of floors: 2
Orientation: south
Planning by:
Schorsch_baut1 May 2024 21:08Why was my comment questioning the price estimate deleted? In 2024, houses with the planned features no longer cost 3100 €/m² (290 €/ft²). With the now larger floor area, the price per square meter would actually be even lower.
Schorsch_baut schrieb:
Why was my comment deleted in which I questioned the price estimate? Houses like these with the planned features no longer exist in 2024 for 3100 €/m² (approximately 288 USD/ft²). Or, with the now larger floor area, the price per square meter would be even lower. Because some people here are acting like they are in control. Better to move to another forum, where you’re more welcome.
2
2024_Häuslebau2 May 2024 07:55I can’t follow the comment, who is playing God here? The price information comes from the construction company; we can’t provide any more details on that.
Are there any ideas on how to avoid the long, rather dark hallway? What do you think about the idea of adding a passage to the living room?
hanghaus20232 May 2024 09:09ypg schrieb:
It is also based on mine from #4I noticed that as well. Thumbs up.H
hanghaus20232 May 2024 09:142024_Häuslebau schrieb:
I can’t follow the comment,This happens quite often here when posts are deleted.H
hanghaus20232 May 2024 09:202024_Häuslebau schrieb:
Are there any ideas to avoid the long, rather dark hallway?A skylight above the staircase can help with that. With the straight staircase in the middle, it is often a problem. In that case, the only solution is a complete redesign.
