ᐅ Floor Plan Optimization for Urban Villa + Considerations for Land Elevation
Created on: 31 Jan 2020 13:29
Shiny86
Plot size 492 sqm (5293 sq ft)
Slope yes
Site coverage ratio?
Floor area ratio?
Building envelope, building line, and boundary?
Boundary development?
Number of parking spaces 2
Number of floors 2
Roof type Pyramid roof, 25 degrees
Architectural style Modern urban villa
Orientation Main entrance facing north
Maximum heights/limits
Additional requirements?
Clients’ Requirements
Modern urban villa with pyramid roof, 25 degrees
Basement, floors 2 full floors without basement
Number of occupants 4
Open kitchen, kitchen island
Number of parking spaces 8-10
Garage
Who designed it?
-Architect
Large living area, master bathroom
What don’t you like? Why?
Utility room quite small and master bedroom small, children’s room somewhat too large
The architect implemented the corresponding wishes
What do you think is especially good or bad about it?
Good: large living area
I am uncertain about the half-height window sizes and the swing direction of the doors
What do you think about the floor plans?
Slope yes
Floor area ratio?
Number of floors 2
Garage
Who designed it?
-Architect
- Where could it still be optimized? Would you recommend different window dimensions or sill heights?
- What do you think is poor or what would you do differently?
- A partition wall will be added in the walk-in closet. That would theoretically allow watching TV from the bed. I am considering a lightweight wall. I plan to place a 211cm (83 inches) Pax combination wardrobe in the closet. The closet is planned with a raw width of 218cm (86 inches). Do you think 218cm is enough for the Pax once the walls are plastered, or how wide should the rough dimensions preferably be?
- Is the hallway on the ground floor too narrow?
- Would you raise the ground level? The house would be 40cm (16 inches) below street level. If I build a terrace into the garden, it would be about 1m (3 ft) difference. You could raise only the house level, resulting in approximately 1.6m (5 ft) difference between terrace and garden. I don’t know anyone living below street level. Raising the garden would probably not be allowed without permits, and affected neighbors likely wouldn’t agree. On the sides of the house adjacent to neighbors, raising is permitted only up to certain limits. I am overwhelmed with the decision.
- Do you have any ideas for arranging the sofa differently and placing the TV sensibly? My husband doesn’t want the sofa back facing a window. I still need to get used to placing the sofa in the middle of the room.
- Is the kitchen size sufficient for a nice kitchen with an island?
Shiny86 schrieb:
It is at least 1 meter (3.3 feet) wide, and not far from there are the 2-meter (6.6 feet) patio doors. I’m not worried about it. But I’ll see how it actually turns out...
If the central controlled residential ventilation is installed in the floor, can I expect to have less ceiling height? What will happen to our 2.55-meter (8.4 feet) ceiling height then? 1 meter (3.3 feet) is not as wide as you might think... actually quite narrow. When the sofa is in front of it, only a small gap remains, to exaggerate a bit...
And 2 meters (6.6 feet) is also not that wide.
In our case, the central controlled residential ventilation on the upper floor was installed in the floor screed. This means you don’t lose any ceiling height.
You just have to make sure that the minimum screed cover is still maintained. I can’t tell you the exact value right now.
Tarnari schrieb:
I think that’s just personal preference. We now have a similar room size with a ceiling height of 2.50 meters (8 ft 2.5 in) and find it completely comfortable. Yes, I know everyone experiences it differently. That’s why I just wanted to point out to pay attention to it and then see if it works for you. A spacious feel depends not only on the floor area but also on the ceiling height.
Sabine
Shiny86 schrieb:
Isn’t it true that during the first 2 years, manual ventilation should be done anyway, even with mechanical ventilation? Definitely during an eastern waning gibbous moon!
