ᐅ Floor plan design for an urban villa of approximately 160 m² without a basement
Created on: 3 Apr 2018 14:35
Z
Zisu2000
we are almost finished with our planning phase. That’s why we would like to hear your opinion on the floor plan of the house. I have been enthusiastically reading this forum for months now. I especially appreciate the helpfulness and the respectful tone here. However, this does not mean you shouldn’t give criticism. We are grateful for any comments or ideas for improvement.
A small issue is the orientation of the plot. Our main facade faces southwest, but once the house is built, there will be only about 6 meters (20 feet) to the neighboring property (depending on where the double garage is placed). The main garden is also oriented to the northwest. We planned the terrace in an L-shape from southwest to northwest. We will probably spend more time on the northwest terrace (which is why there is a sliding door leading outside there). If the main facade (living/dining area) were oriented northwest, I think the living room might become too dark (north-facing). But I’m open to being corrected if that is not the case.
Initially, there was an office planned on the ground floor. But that would have made the kitchen too small. We have now planned the office on the upper floor, which is fine for us. The bathroom is located on the north side but has a good size (should be sufficient). At first, we wanted a T-shaped layout (probably because it is often seen in model homes and we liked it there). However, I think an L-shaped layout might be better here. In front of the toilet, there is a planned privacy wall about 1 meter high (3 feet).
I have marked the floor plans with compass directions and measurements. The house measures about 10 x 10 meters (33 x 33 feet) externally (this does not have to remain that way). I also sent furnished versions of the floor plans. The plot is included as well, but without a building envelope shown (full width and about 20 meters (66 feet) deep from the street). The attached exterior views match the floor plan, except the street view on the ground floor has changed slightly (kitchen and pantry windows are different from the exterior view). Additionally, in the floor plan, the sliding door in the living room has been shifted slightly inward to avoid the couch blocking access to the terrace.
For the exterior views, the street is unfortunately shown on the wrong side (now southeast as per the floor plan). We had originally planned for a different plot, but there were some issues (slope, etc.). We were able to acquire this plot at short notice. The garage is also shown rotated and does not necessarily have to have a separation from the house.
I’m sure I have forgotten some things but I will try to answer your replies as quickly as possible. We are looking forward to your opinions/criticism.
Best regards from Bavaria
Plot size: approx. 825 m² (approx. 8,880 sq ft)
Slope: none
Floor Area Ratio (FAR): 0.4
Building Coverage Ratio / building envelope / building line and boundary: Building envelope covers the full width of the plot, about 20 meters (66 feet) deep from the street
Edge development
Roof style: gable roof, hip roof, shed roof
Architectural style: urban villa
Orientation: freely selectable
Maximum height restrictions: max. 8 meters (26 feet) height
Other requirements
Style, roof shape, building type: urban villa, hipped or pyramid roof with 22-degree pitch
Basement, floors: slab-on-grade only, 2 full floors
Number of occupants, age: 2 persons (33, 30)
Space requirements ground floor, upper floor: approx. 80 m² (860 sq ft), total approx. 160 m² (1,720 sq ft)
Office: family use or home office? family use
Guest stays per year: approx. 10
Conservative or modern style: modern
Open kitchen, cooking island: open kitchen with island
Number of dining seats: 4–6
Fireplace: yes, currently not shown on plan (not sure where exactly yet)
Music/stereo wall: no
Garage, carport: double garage, preferably right side of the house (flush) at the property line, exact location still uncertain
Other wishes / special features / daily routines, please also explain reasons why or why not:
Must have:
- large open living/dining/kitchen area
- bright living/dining area with 5 floor-to-ceiling windows here
- pantry
- large bathroom (hence swapping with office/guest room)
- fireplace
- walk-in closet
Who designed the plans:
- planner from a building company (originally with office on ground floor)
- do-it-yourself (current plan slightly adjusted since office on the ground floor was removed)
What do you especially like? Why?
- large open living/dining area
- pantry
What don’t you like? Why?
- is the entrance area big enough?
- is parking on the right side directly next to the house possible and convenient?
- entrance unfortunately on the right side of the house, not at the front; not a big problem
Price estimate according to architect/planner: approx. €290,000 (house and slab only)
Personal price limit, including fixtures and fittings: approx. €400,000
Preferred heating system: air-to-water heat pump, full underfloor heating
If you had to give up something, which details / features?
- could give up: straight staircase (could have a different shape)
- could not give up: large living/dining area, open kitchen, fireplace
Initially planned with office on the ground floor. The technical room was in front of the kitchen (now pantry), which made the kitchen too small (noticed during measuring). The office has now been replaced with the technical room and moved upstairs (which is okay for us).
Which client requests have been implemented?
Almost all, but at that time still with office on ground floor
What makes it particularly good or bad in your eyes?
Is the layout okay? Is the hallway spacious and bright enough? Should rooms be arranged or divided differently? Is sun orientation okay?
Floor plan of a house with kitchen, living/dining area, hallway, stairs, pantry, cloakroom, WC, entrance
Floor plan of a house with bedroom, bathroom, children’s room, walk-in closet, office/guest, hallway and stairs.
Floor plan: open living/dining area left, kitchen bottom right, hallway with stairs, utility/technical room, entrance
Floor plan of a house with bedroom, children’s room, walk-in closet, office/guest, bathroom, hallway and stairs.
Site plan of a plot with parcels, measurements and street names
Modern white two-story house front with dark roof and double garage, in front of green area and street.
White two-story house with dark hip roof and rectangular extension in front of trees.
Modern white two-story house with dark roof and large glass windows.
Two-story modern single-family house with dark gable roof, large windows and garage
kaho6744 Apr 2018 21:26
Here is the modern version without expensive additional roofs on the ground floor, but finally including a pantry and a slightly larger utility room plus a fireplace.
A designer should probably revisit the window optimization. It can definitely be improved. Depending on the terrace location, a patio door should be added next to the kitchen at the top of the plan.
Two-story gray house with wood-framed windows; interior visible through glass facade.
Floor plan of an apartment: child’s room, dressing room, bedroom, bathroom, office, hallway.
Floor plan of a house: open living area, dining area, kitchen with island, fireplace, entrance hall, utility room, WC, pantry.
Access to the dressing room can optionally also be through the bedroom. Additionally, it might be worth considering removing the doors between the kitchen and living room along with the associated small walls.
Z
Zisu2000
4 Apr 2018 22:58
Hmm, the bottom floor is actually not bad. It already looks quite spacious. I just don’t understand the utility room. Can the utility room be seen from the stairs? Its length extends all the way to the middle of the staircase?
Upstairs, a lot of space seems to be wasted due to the stairs and the large hallway. Maybe it just appears that way. I need to measure everything carefully.
Z
Zisu2000
4 Apr 2018 23:15
If the dimensions are correct, then almost all the rooms upstairs are smaller than in my initial floor plan. It seems a lot of space is lost due to the hallway.
Wickie
5 Apr 2018 07:57
I would prefer to give up a few square meters but have fully functional rooms!
As is often the case in life: size alone doesn’t make the difference.
I find Katja’s floor plan very well balanced!
kaho6745 Apr 2018 08:04
Zisu2000 schrieb:
If the dimensions are correct, then almost all the rooms upstairs are smaller than in my original floor plan. It seems a lot of space is lost due to the hallway.
No idea. Here are some measurements from the upper floor:
Floor plan of an apartment with bedroom, child’s room, bathroom, office, corridor, and dressing area.
As I said, size isn’t everything. The thickness also matters!
kaho6745 Apr 2018 08:12
Next option:
Orientation this time only towards the southwest – a bit narrower to allow for a terrace there.
Straight staircase – yippee.
Storage again under the stairs.
Nice wide entrance.
Even an optional shower downstairs.
Large utility room.
Ideal with a small balcony on the upper floor for the child. If that’s too expensive, some kind of small roof will have to be built over it.
Floor plan of a level with bedroom, office, child’s room, walk-in closet, shower, staircase.
House floor plan: kitchen with island, dining area, living room, stairs, bathroom, technical room.
Note: The staircase is the small 3.60m (12 feet) one from the introductory thread. Nothing bigger was possible. But it could be widened at the bottom – as is common in mansions. We’ll see if I can find a picture...
