ᐅ Floor plan of a 200 m² single-family house, raised ground floor, existing plot, double garage
Created on: 6 Feb 2025 23:45
Gustav5789
Dear collective wisdom,
We would like to build our single-family home on the parents-in-law’s property. The target is about 200 m² (2,150 sq ft) with a double garage. Our architect is very creative, which we find somewhat unsettling, so I’m seeking advice here.
Plot size: 1200 m² (13,000 sq ft), our portion will be approximately 550 m² (5,920 sq ft) in the future
No slope present → farmland (1549) but lies 1 m (3 ft) below the plot
Floor area ratio unknown
Site coverage ratio unknown
Building envelope, building line, and boundary unknown
Surrounding development unknown
Number of parking spaces: 1.5
Number of floors: 2
Roof shape: no specifications
Architectural style: no specifications
Orientation: no specifications
Maximum height/restrictions unknown
Other conditions
Existing setback areas must be reapplied for
Owner requirements
Architectural style, roof type, building type
Classic single-family home with a pitched roof
Basement, floors
No basement, two full floors
Number of people, ages
5 people, 33, 31, 2, 0 (planned)
Office:
Home office P1 4 days + P2 2 days
Guest bedrooms per year
None
Open or closed layout
Open
Conservative or modern construction
Modern
Open kitchen, kitchen island
Open kitchen, U-shaped
Number of dining seats
Minimum 8, ideally 10
Fireplace
Wood stove (optional)
Music / stereo wall
Stereo wall (optional)
Balcony, roof terrace
No balcony, roof terrace (optional)
Garage, carport
Double garage, extra wide/deep (7.5 x 9 m (25 x 30 ft))
Utility garden, greenhouse
Utility garden
Additional wishes / special features / daily routine, including reasons for preferences
Due to flooding events, the house should be built 1 m (3 ft) above ground level; garages may remain at ground level
Existing building requires more parking than the existing double garage, at least 3 spaces
Garages on the east side because parcel 1560/6 has a continuous 10–12 m (33–39 ft) tall tree/bush line on the boundary
Do-it-yourself
Ground floor: Open living and dining area; kitchen is directly integrated into life at the table
Ground floor: Pantry between work area and kitchen serves as an acoustic buffer
What do you dislike? Why?
Ground floor: TV with stereo should ideally face the table to fill the whole room with sound
Upper floor: Too convoluted; children’s rooms are under 15 m² (160 sq ft)
Upper floor: No space for drying/ironing laundry
Garage: Technical room would be flooded during high water
Estimated cost according to architect/planner:
750,000 euros
Preferred heating technology:
Heat pump
If you have to forego, which details or features could you do without?
- Roof terrace
- KfW 40 standard (energy efficiency standard)
- Wood stove
- Large garage
- Utility garden
- 15 m² (160 sq ft) per child’s room
Which features are indispensable?
- Three children’s bedrooms
- Home office
- Open living area
- Second bathroom
A mix of many examples, trying to save square meters and fit everything into 180 m² (1,940 sq ft), but now we are happy to build larger since permission up to 272 m² (2,930 sq ft) was approved.
What wishes were fulfilled by the architect? None yet; he has only provided proposals we don’t necessarily like.
What do you consider particularly good or bad about it?
We like the ground floor layout; technical areas cause little noise inside as they are separated.
Original: https://www.hausbau-forum.de/threads/kombination-massivhaus-vs-holzrahmenbau.48745/
The plot plan originally anticipated reusing existing prefabricated garages; however, these have been sold, so we have a free hand.
Ground floor plan of a house with kitchen, living room, bedroom, bathroom, utility room, and stairs.
Floor plan of a house with several rooms, staircase, bathroom, kitchen; area labeled in m².
Site plan of a plot with red dashed outline around building plot 1549/4.
Site plan showing existing and new building areas, red outline and measurements, north arrow.
A black car parked in front of three brown garages, wet paved driveway, surrounding trees.
K a t j a21 Feb 2025 16:43
Regarding ceiling heights, I wanted to add that the existing house already has pretty decent values. Okay, the ceiling height on the upper floor isn’t amazing if it’s actually only 2.25m (7 ft 5 in). However, there is a 40cm (16 in) knee wall in the attic. You could basically approach the building authority and say you want to build almost the same as the existing house, just 50cm (20 in) higher due to flood protection. Then see what they say. If they refuse, there is still the option to work with a 2.10m (6 ft 11 in) knee wall on the upper floor or something similar. Everything in between is probably negotiable. Either way, I think the best option is to develop the attic for the parents.
By the way, I optimized the last design to external dimensions of 11m x 9.2m (36 ft 1 in x 30 ft 2 in). Including the attic, this gives a total of 198.2 sqm (2,134 sq ft), with all areas under 2m (6 ft 7 in) height counted as half, and boxed-in areas counted as zero. The smallest child’s room is 15.4 sqm (166 sq ft).
Gustav5789
21 Feb 2025 22:25
Thank you for all your hard work, Katja. Our architect will be available again starting Monday, and then I will keep bothering him about the height issue until he can give us an answer. I really like your plan with the three floors. Just a few minor details, but we are currently trying out a few different house placements on the plot to get a better sense of it. I will try to get back to you next week with new information and more ideas.
I will present the argumentation as it stands.
21 Feb 2025 22:57
K a t j a schrieb:
You can immediately feel how everything relaxes.
At what height under the roof does your 2-meter (6 ft 7 in) mark lie? Are the walls at 1.30 meters (4 ft 3 in), or is it lower?
K a t j a21 Feb 2025 23:16
Where is your 2-meter (6 ft 7 in) mark under the roof? Are the walls at 1.30 m (4 ft 3 in)? Or is it shallower?
The 2 m (6 ft 7 in) line is drawn and should be around 2.85 m (9 ft 4 in). The knee wall with a height of 1.30 m (4 ft 3 in) is at about 1.85 m (6 ft 1 in). Why do you ask? Did I miscalculate?
21 Feb 2025 23:23
K a t j a schrieb:
The 2m (6.6 ft) line is drawn in and should be around 2.85m (9.3 ft). The knee wall with a height of 130cm (51 inches) is at about 1.85m (6.1 ft). Why do you ask? Did I miscalculate?
No, or rather, I’m not sure. I just want to understand your drawing and the measurements. In the end, there aren’t any clear references, only a “1.30m” (4.3 ft) appearing in some areas that can’t be assigned. I know your software has some quirks, just like mine does.
Are those then the continuous lines?
K a t j a22 Feb 2025 00:08
Yes, the continuous line represents the 2m (6.6 ft). The 130 is the knee wall height.
