ᐅ Floor plan 120 m², single-family house 1.5 stories, carport. Opinions, ideas, suggestions?
Created on: 22 Jun 2022 16:17
Wattfraß
Hello dear housebuilding community,
we are planning to build a new single-family home next year and came across this forum. We would like to share our floor plans with you and look forward to your feedback and possible suggestions for improvement:
- Plot size: 610 m² (6565 sq ft)
- Slope: gentle south-facing slope
- Site coverage ratio: 0.4
- Floor area ratio: 0.8
- Maximum eaves height: 6.0 m (20 ft)
- Maximum ridge height: 12.0 m (39 ft)
- Building boundaries: minimum distance of 4 m (13 ft) from the street edge
- Garage/carport boundary: within building boundaries, minimum distance of 6 m (20 ft) from the street edge
Homeowners’ Requirements
- Number of parking spaces required: 2
- Number of storeys: 1.5
- Roof type: gable roof, 35° pitch
- Style: classic single-family home
- Orientation: living and dining area facing southwest
- Basement, floors: no basement required
- Number and age of residents: 2 adults, 2 children
- Room requirements on ground floor and upper floor: 3 bedrooms upstairs
- Office: no office required
- Guest rooms per year: no guest room required
- Open or closed architecture: open concept towards the garden
- Conservative or modern design: modern design with open kitchen featuring an island
- Number of dining seats: 6
- Fireplace: yes
- Balcony, roof terrace: no balcony, terrace
- Garage, carport: possibly a carport, plus 2 parking spaces in front
- Planned by: contractor’s in-house planner
- What do you like most? Why?:
We like the floor plans because all our wishes have been implemented functionally. We especially like the exterior appearance with the large windows.
We also appreciate the floor-to-ceiling window between the kitchen backsplash and the island.
- What don’t you like? Why?
We are uncertain about the staircase (shape, position, daylight) and the hallway leading to it.
Is the corridor from the front door to the stairs perhaps a bit long?
The hallway upstairs is very wide but lacks natural light. Adding another window on the east side would disturb the exterior appearance.
The niche planned for the kitchen has a clear width of only 2.70 m (8 ft 10 in). After accounting for plaster and construction tolerances, there will probably be space only for four 60 cm (24 in) wide kitchen cabinets.
The house position on the plot is also not yet fixed. The plot is approximately 28 m (92 ft) long from northwest to southeast and about 23 m (75 ft) wide. A minimum distance of 4 m (13 ft) from the street edge applies on the northwest and northeast sides. The carport must be at least 6 m (20 ft) from the street edge. Currently, we have three options for the house placement:
a) At the northwest boundary with a 4 m (13 ft) distance from the street edge (advantage: maximum garden area on the south side; disadvantage: proximity to neighbor on the west)
b) At the northeast boundary with a 4 m (13 ft) distance from the street edge (advantage: maximum distance from the neighbor on the west, plenty of space for garage on the west; disadvantage: 8 m (26 ft) wide green strip north of the house >> much garden space is unused)
c) Centered on the northern curve with a 6 m (20 ft) distance to both mentioned street edges (compromise between the above two options; equal distance from both streets)
Which option would you prefer, considering the carport location?
- Preferred heating system: air-to-water heat pump
- What makes it, in your opinion, especially good or bad?:
Very good implementation of our ideas and budget
What is the key/basic question about the floor plan in 130 characters?
See the section "What don’t you like? Why?"
Thank you in advance for your feedback!
Site plan of a building plot with color-marked areas and access roads
Modern kitchen with grey base cabinets, wooden countertops, sink, and island with cooktop
Floor plan of an apartment: open living/dining/kitchen area, hall, bathroom, shower, stairs
Floor plan of a house upper floor: hallway, bedroom with walk-in closet, bathroom, and two children’s rooms
Cross-section of a multi-storey house with roof structure, windows, and foundation, with measurements
Small white single-family house with dark gable roof, two windows, side path and garden
White two-storey house with grey roof, terrace, garden and barbecue area
Aerial view of a residential area with red plot highlight and surrounding houses
K a t j a28 Jun 2022 14:22
Please provide the exact wording of the development plan regarding the carport regulation here.
What are the dimensions of the curve of the property boundary (where does the curve start)?
Pitiglianio
28 Jun 2022 14:42
So the ground floor with a utility room size of 4 square meters (43 square feet) or more does not work because it is too small.
In the other proposal, I still find the ground floor bathroom too large. Shower because of the dog?!
Install an outdoor water tap at the carport/garage area, since that’s where you wash the dog. Your house is too small for such luxuries.
The same applies to the kitchen island... the house is too small for that. There are great options to plan with an L-shaped kitchen here.
Regarding the stairs: Since there are no dimensions, one can only assume that the staircase in the design is too small.
SoL
28 Jun 2022 14:56
One more well-intentioned tip: You have a 2.5m (8 feet) slope on your plot. What are you planning to do about it? Build up the ground? Maybe consider using the slope instead? What have the neighbors done?
28 Jun 2022 15:02
SoL schrieb:
Just the ground floor option 3 (EG3) that you like:
It’s about the sketch, the concept, the layout…!
SoL schrieb:
Just the ground floor option 3 (EG3) that you like: kitchen island positioned so that you can squeeze past one side with about 50cm (20 inches) of space, and a bit of clearance on the other side near the chimney, allowing for a wood stove upstairs.
Of course, it’s not detailed. Just because someone drew a stovepipe right in the middle in an impractical location, plus an oversized kitchen island, doesn’t make it settled for me.
But I would definitely take ground floor option 3 (EG3) as a basis for discussion and a starting sketch!
Nothing is final… or as others here often say, “final.”
K a t j a28 Jun 2022 15:15
Especially not as long as the carport is not positioned on the plot together with the house.
driver55
28 Jun 2022 15:40
Wattfraß schrieb:
The construction contract has already been signed.
Well, good luck with that.
(Almost) a complete waste of time for everyone involved here, what a pity.
