ᐅ Fixing Squeaky Billy Shelves: What Tips and Tricks Work?
Created on: 20 Jul 2024 18:37
Milemo
Milemo
20 Jul 2024 18:37
I recently assembled a BILLY bookcase from IKEA, and unfortunately, it makes a creaking noise with every small movement or load, which is quite annoying. The bookcase stands firm, but the creaking is just irritating.
I have already tried tightening the screws, but that didn’t help much. My guess is that the wood is rubbing in some places or the fasteners are slightly stiff, causing the creaking sounds.
So my question to the community is: What tricks or tips do you know to fix creaking in BILLY bookcases? Are there specific lubricants, DIY hacks, or methods to make it quiet permanently?
I’m grateful for any advice, even if it’s based on experience with other IKEA furniture. Thanks in advance!
TEOZAR
20 Jul 2024 19:42
Hello Milemo,
Your issue is actually quite common with BILLY shelves and similar wooden furniture. The creaking usually comes from friction between wood and metal or from slight gaps that can be worsened by humidity or minor material expansion.
A proven tip is to carefully check all connections and then apply a suitable lubricant. However, you should avoid using a lubricant that is too thick, as it attracts dust. WD-40 spray is often the go-to for metal parts, but for wood-to-wood contacts, I would recommend beeswax or pure paraffin instead.
Alternatively, you can gently sand the wooden contact points with fine sandpaper to smooth out any roughness. It also helps to carefully loosen all screws and dowels and then retighten them firmly, but not too tight. Important: overtightening can create new stresses and actually increase creaking.
If your shelf is placed directly against a wall, make sure it is slightly adjusted to avoid unnecessary pressure.
If you don’t mind the shelf getting slightly rubbed, adding a piece of felt or foam rubber in problem areas can also help reduce friction.
I hope this gives you some practical pointers. 🙂
Greglau
20 Jul 2024 20:05
TEOZAR schrieb:
A proven trick is to thoroughly check the connections and then apply a suitable lubricant.
I can confirm this. What helped me was slightly loosening the screws, then applying some wax to the contact points, and finally tightening them again. No more creaking.
dijan
21 Jul 2024 10:33
Milemo schrieb:
What tips or tricks do you know for fixing squeaking in BILLY shelves?
Hey Milemo! Squeaking is definitely the unwanted soundtrack for many pieces of furniture. For me, rubbing baby powder into the wooden joints really helped – it reduces friction without having to oil the entire shelf. Just carefully apply a little powder along the edges and spread it out.
Another great tip: felt pads, as TEOZAR already mentioned, can be stuck in places where metal meets wood. This makes the shelf quieter and feels better over time. And honestly, a bit of peace when it comes to furniture is always welcome, right? ;-)
nubar
22 Jul 2024 08:27
The issue of squeaking in a BILLY shelf is complex because it can have both mechanical and material-related causes.
On one hand, it can be helpful not only to check the screws and dowels but also to clean the exact mounting surfaces. Dust or small wood splinters can cause movement and squeaking.
On the other hand, a combination of lightly applying a dense wax (not a liquid oil) to the wooden parts and a dry lubricant to the metal connections often proves effective.
Another useful tip: check the floor beneath the shelf. Unevenness can lead to micro-movements that cause squeaking. Placing thin felt pads or a carpet underlay can actually make a significant difference.
Finally, a piece of advice: avoid aggressive or highly moisture-intensive products, as these can cause the material to swell or warp, potentially worsening the problem.
