I am planning to equip my BILLY bookshelf from IKEA with glass shelves but don’t have much experience with this yet. I am particularly interested in whether glass shelves are generally suitable for the BILLY unit, especially regarding load-bearing capacity and stability. Are glass shelves reliable and safe for holding regular to somewhat heavier books or decorative items?
Additionally, I would like to know if I need special fittings or modifications to securely install the glass shelves, or does the standard BILLY system allow this without any issues?
I look forward to your assessments, and perhaps you have practical tips for installation or experience with glass shelves in BILLY. Thanks in advance!
GUMARTINA3 Feb 2019 19:02Glass shelves generally fit into the BILLY, but they are not designed for heavy loads.
Their load capacity is lower than that of wooden shelves.
Make sure to use the supplied brackets correctly. If your items are heavy, it is better to choose wooden shelves.
I would like to add that the glass shelves from BILLY are usually about 10 mm (0.4 inches) thick and can support a load of approximately 7–10 kg (15–22 lbs) per shelf, depending on the width of the unit.
Exactly, it is important to use the designated metal pins or clips, as they distribute the weight better than simply placing the shelf without support.
If you plan to store heavier books, I recommend wooden shelves or additional reinforcement, for example with special glass shelves of greater thickness, which are not standard offerings from IKEA.
The assembly itself does not require special modifications as long as original components are used.
Perhaps I can add some information regarding safety and installation techniques.
Glass shelves in BILLY look nice if you want to create a more open or airy appearance. However, I would advise against overloading glass shelves with books, as the glass surface can easily break or bend under too much weight. Instead, they are ideal for light or decorative items.
Basically, glass shelves tend to flex more in the middle than wooden ones, so any point load will have a greater impact. Make sure the brackets are properly fitted and not tightened too much or too loosely during installation.
From my experience: glass holds up well if handled carefully, but it is not really recommended for heavy books.
If you still want glass, you can also check with specialized stores for thicker glass that can be cut to size—just be sure to also verify the brackets and structural stability in that case.
I hope this helps! 🙂
ixpera schrieb:
Specifically regarding load-bearing capacity and stability
A supplementary guide for glass shelves in BILLY:
1. Glass thickness: IKEA typically uses 10 mm (0.4 inches) thick glass for BILLY shelves. This thickness offers limited load-bearing capacity.
2. Dimensions and fit: Check that the glass shelves are precisely matched to the BILLY shelving unit, especially the cutouts for the support brackets.
3. Fixing: Use the original clips/brackets. These are designed to hold the glass securely without applying excessive pressure on the edges, which can otherwise cause cracks.
4. Load capacity: The maximum load is usually around 7 kg (15 lbs) per glass shelf. It is better to distribute heavy loads across several levels.
This is an important point, as glass is very sensitive to pressure. Many users underestimate the risk of glass breaking under localized overloading.
Summary: Glass shelves in BILLY are well suited for decorations or lighter items, but for books or heavier objects it is better to use wooden shelves or add additional supports.
If you have any questions about installation, I’m happy to help.
Kinbu schrieb:
Glass holds up well if handled carefully, but it is not recommended for heavy books.
