ᐅ Fitting KALLAX with casters – is it worth the investment?
Created on: 19 May 2022 08:47
NONSO
I am considering adding casters to my IKEA KALLAX shelving unit to make it easier to move around the room. I find it especially useful to be able to shift furniture easily in smaller apartments or multipurpose rooms.
My question is: Is it really worth investing in casters for the KALLAX unit? Has anyone had experience with whether the casters are sturdy enough to support the weight and if the extra effort in terms of installation and cost is really justified?
It would also be important for me to know if there are any practical limitations – for example, regarding the load capacity, the stability of the shelving unit, or whether the casters work well on different floor types.
I look forward to your experiences and opinions!
leguson
19 May 2022 13:45
I have also installed casters and can say: they need to be lockable and stable.
Sometimes it helps to additionally attach brackets to the base plate to provide extra support.
enrique7
20 May 2022 08:17
ODINFLO schrieb:
You should clearly weigh the advantages and disadvantages and avoid installing the casters without additional stabilization.
A very important point!
Another issue is that you might need to adjust the original shelves inside if the height of the casters varies.
Additionally, there is the question of whether the casters provide enough support to absorb vibrations without the shelving unit tipping over or shifting.
NONSO
20 May 2022 09:56
Thank you very much for the very helpful contributions so far!
One more question: Is it really necessary to secure the KALLAX to the floor or wall in addition to the casters? Or is the locking function of the casters usually sufficient?
Also, do you have any tips on which types of casters and diameters work best? I often see very different recommendations.
todunar
20 May 2022 11:23
NONSO schrieb:
Is it really necessary to secure the KALLAX units to the floor or wall in addition to the casters?
Personally, I decided against securing them because I love the flexibility. My casters have a very strong locking brake, so the shelf stays completely stable when not being moved.
Regarding caster diameter: In my opinion, 50-60 mm (2-2.4 inches) casters are a good compromise – they roll well on both carpet and hard floors. Smaller casters tend to get caught on carpet sometimes. 🙂
V
Vinlen
21 May 2022 07:59
NONSO schrieb:
Is it really necessary to secure the KALLAX and the casters to the floor or wall as well?
If you have children or pets at home, I would definitely recommend securing it to the wall.
Lockable casters provide stability, but they are not a substitute for a secure fixing.
Although it requires a bit more effort, the combination of lockable casters and wall fixing offers the best mix of safety and flexibility.
