ᐅ Electrical Planning – Is Something Missing?
Created on: 2 Mar 2016 14:14
andimann
Hi everyone,
things are starting to get serious for us. It’s time to think about the basic locations and quantities of power outlets, light fixtures, network connections, satellite connections, and conduit pipes.
I’ve roughly sketched and attached my current planning status. Maybe someone has helpful feedback for me? Does anyone see a spot where I definitely need a network connection, conduit, or something similar?
To explain:
· We’re also installing a controlled mechanical ventilation system, which will be embedded in the screed of the basement ceiling and the ground floor ceiling. Because of this, we can’t lay conduits inside the screed insulation, as that would interfere with the ventilation’s oval ducts. I’m also generally not a fan of conduits with bends and curves. Therefore, my plan is to run conduits vertically down the walls to the basement whenever possible and then gather the cables there in cable trays.
· The current plan shows a full installation of satellite connections and network outlets. All of these will be laid in conduits that will only be filled “when needed.” Child 1 is currently 16 months old, and Child 2 is still in planning. So it will be at least 10 years before satellite or network connections are needed in the children’s rooms. By then, there will probably be entirely different technologies.
· The recessed ceiling spots will be cast into the precast concrete ceiling, so there will be no suspended ceiling.
· The various conduits on the ground floor will simply run straight down to the basement. From there, I can route the cables openly below the ceiling to the switch, satellite system, or 5.1 receiver (which will be located under the TV in the living room).
· Likewise, the cables for network and satellite from the guest room, living room, and bedroom will be laid in conduits running straight down. The endpoint is again at the basement ceiling exit. From there, cable routing will be either open or in cable trays.
· In the office on the upper floor, there is a small tech shaft that runs down through the pantry on the ground floor into the technical/laundry basement. The cables for the office and Child 1’s room will run through this shaft.
· Child 2’s room is still a bit of a concern. The room is completely cantilevered over the living room, so there is no wall underneath where I could run a conduit down. I would have to somehow work through the dressing room. In the worst case, I’d route the cables openly in the dressing room and then together with the bedroom cables down to the basement.
· In general, I am only having conduits and empty boxes prepared inside the walls; I will install the network and satellite system myself.
Thanks and best regards,
Andreas
Uwe822 Mar 2016 16:22
New cables are not as flexible as one might think, and often you have to put in a lot of effort to prevent them from getting stuck in curves. Replacing them is easier: connect the cables and pull from one end.
V
Vitalio
2 Mar 2016 17:08
Child 2 door swing is incorrect, or the electrical outlets need to be where the network outlets are, as Uwe already mentioned; in the child's room, the network outlet must be behind the desk.
Shutters manual or electric?
At each of our windows, there is a timer-controlled outlet for Christmas lights. The stairway light (basic lighting) is also timer-controlled. Spotlights above the toilet and shower are controlled by motion sensors (I would swap toilet and shower spots. The toilet is only used in the morning and evening, so daylight can be neglected there; you don’t need to cross the entire bathroom to get to the toilet. Plan a wall outlet above the washbasin. Planning just a mirror is pointless; after about two months, you’ll hear “We need a mirrored cabinet.”
I would also plan a network outlet in the kitchen.
For the walk-in closet, I would install at least 3–4 spotlights, and the stairwell as well.
Also, one at the bathroom entrance; you might need an electric towel rail to heat the bathroom. In the bedroom, you can add a light switch next to the bed, and definitely USB outlets next to the nightstands (I still need to change that myself).
One outlet next to every door is enough (for a vacuum cleaner?), but instead, it’s better to install a stairway switch so that the stairway light can be turned ON/OFF from every room when entering or leaving. Don’t forget network connections for controlled mechanical ventilation and heating.
V
Vitalio
2 Mar 2016 17:16
How wide is the landing at the top? Is it not possible to do without these 45-degree angles in the children's room?
If the staircase is not planned to be 80cm (32 inches) wide, then you have at least 2.1m (7 feet) there, which is sufficient for two 86.5cm (34 inches) doors.
toxicmolotof
2 Mar 2016 17:26
16 satellite connections? That’s more than in some apartment buildings.
And I thought I had been generous with my 7 connections.
Sebastian79
2 Mar 2016 17:28
Most likely double conduits – we have 12 conduits, with one double conduit in the living room. Elsewhere, I found that unnecessary.
Sebastian79
2 Mar 2016 18:01
Satellite cables, not LAN
We also have 45-degree walls, which I find a bit excessive here too – did you paint it yourself?
