ᐅ Electrical Planning – Is Something Missing?
Created on: 2 Mar 2016 14:14
andimann
Hi everyone,
things are starting to get serious for us. It’s time to think about the basic locations and quantities of power outlets, light fixtures, network connections, satellite connections, and conduit pipes.
I’ve roughly sketched and attached my current planning status. Maybe someone has helpful feedback for me? Does anyone see a spot where I definitely need a network connection, conduit, or something similar?
To explain:
· We’re also installing a controlled mechanical ventilation system, which will be embedded in the screed of the basement ceiling and the ground floor ceiling. Because of this, we can’t lay conduits inside the screed insulation, as that would interfere with the ventilation’s oval ducts. I’m also generally not a fan of conduits with bends and curves. Therefore, my plan is to run conduits vertically down the walls to the basement whenever possible and then gather the cables there in cable trays.
· The current plan shows a full installation of satellite connections and network outlets. All of these will be laid in conduits that will only be filled “when needed.” Child 1 is currently 16 months old, and Child 2 is still in planning. So it will be at least 10 years before satellite or network connections are needed in the children’s rooms. By then, there will probably be entirely different technologies.
· The recessed ceiling spots will be cast into the precast concrete ceiling, so there will be no suspended ceiling.
· The various conduits on the ground floor will simply run straight down to the basement. From there, I can route the cables openly below the ceiling to the switch, satellite system, or 5.1 receiver (which will be located under the TV in the living room).
· Likewise, the cables for network and satellite from the guest room, living room, and bedroom will be laid in conduits running straight down. The endpoint is again at the basement ceiling exit. From there, cable routing will be either open or in cable trays.
· In the office on the upper floor, there is a small tech shaft that runs down through the pantry on the ground floor into the technical/laundry basement. The cables for the office and Child 1’s room will run through this shaft.
· Child 2’s room is still a bit of a concern. The room is completely cantilevered over the living room, so there is no wall underneath where I could run a conduit down. I would have to somehow work through the dressing room. In the worst case, I’d route the cables openly in the dressing room and then together with the bedroom cables down to the basement.
· In general, I am only having conduits and empty boxes prepared inside the walls; I will install the network and satellite system myself.
Thanks and best regards,
Andreas
Bauexperte
3 Mar 2016 11:15
Reading your thoughts on lighting here, I get the impression that you all prefer to live in showrooms. I, on the other hand, like it cozy; if I need floodlighting, I simply switch on the ceiling lights temporarily.
I get the same feeling when I read about how many power outlets are planned or required per room. One thing is for sure—your electricians will be happy.
Regards, Bauexperte
j.bautsch
3 Mar 2016 11:27
Some people simply prefer bright spaces, like me—I can never turn on enough lights or use bulbs with enough watts in the fixture. My husband doesn’t understand it either; he’s more of a person who likes dim, cozy environments.
Jochen1043 Mar 2016 11:31
We also have a floor lamp in the living room (the typical one from Ikea) that is sometimes turned on to create a cozy atmosphere. However, this only happens rarely. That’s why the recessed lights in our living room ceiling are wired on separate switches.
When it’s really cozy, only the firelight from the fireplace is lit anyway.
Regarding electrical outlets: our electrician was very relaxed about this despite the fixed price. He even made suggestions on where additional outlets should be placed.
Sebastian79
3 Mar 2016 11:32
You can never have too many power outlets... there’s always one missing in the end.
Bauexperte
3 Mar 2016 11:35
Sebastian79 schrieb:
You can never have enough power outlets... there’s always one missing in the end.
In my opinion, it depends on how much consumption the individual expects to need.
Regards, Bauexperte
Sebastian79
3 Mar 2016 11:41
Strange statement... but that's just the "imho".
