ᐅ EKBY BJÄRNUM vs. DIY Assembly
Created on: 4 May 2016 12:09
TobWen
TobWen
4 May 2016 12:57
A toaster placed at that height—is it still easy to use?
edit: Oh, I see, just for placing it there. That stuff doesn’t weigh that much, right? The load capacity is specified up to 20 kg (44 lbs).
No, it’s all very light. I just want to keep the countertop clear. At the moment, it’s in the cabinet or the stuff is visibly on the countertop... The coffee machine will stay there.
Actually, the LACK shelf might almost be enough, right? It would come with mounting hardware included.
IKEA-Experte
4 May 2016 13:05
I would have some concerns about using LACK on a drywall (gypsum board) wall.
There are also the following options:
VÄRDE wall shelf with 5 hooks, birch
Wood wall shelf with two boards and hooks, ideal for hallway.
Grundtal wall shelf, stainless steel
Wall-mounted metal wire shelf with two hooks and bowls on it
SKOGSTA wall shelf, acacia
Wood wall shelf with wooden panel back in brown wood finish
TobWen
4 May 2016 13:14
Yes, I have already seen VÄRDE and actually think it’s great. But the top shelf would be too high, and I would basically have to position the fuse box between the two panels – as you can see from my kitchen. It’s 160 cm wide, by the way (exactly 163 cm).
Unfortunately, I don’t know the distance between the individual shelves. I’ll measure it virtually right now.
Edit 1: The photogrammetric analysis showed a distance of 20 cm between the shelves. The fuse box is 22 cm high. Mission failed.
Edit 2: Great, VÄRDE is not available at all in Essen, just like the small NOT (I got the large NOT in Dortmund for 9.90 EUR!!!)
Edit 3: Too bad, it would have looked nice:
Kitchen unit with countertop, toaster oven, kettle and spices
IKEA-Experte
4 May 2016 13:29
In white, it is also available in Essen, but then not in solid wood. You will need to decide for yourself which height is comfortable for your height, whether the fuse box fits in between, and so on. The VÄRDE shelf will definitely be discontinued soon. The shelf was part of the VÄRDE modular kitchen. In general, many family offers are phase-out items.
TobWen
4 May 2016 13:30
In white, it is also available in Essen, but then it’s not solid wood. You will have to decide what height is convenient for your height, whether the fuse box fits in between, and so on. The VÄRDE shelf is probably going to be discontinued soon. The shelf was part of the VÄRDE modular kitchen. In general, many Family offers are clearance items.
Since the countertop is in between, I won’t be able to reach the very top... 21 cm (8 inches) isn’t really very deep either.
Color-wise, white would probably fit best, don’t you think?
IKEA-Experte
4 May 2016 13:59
It depends on whether you prefer everything to be a single color or want to introduce some variation right away.
