ᐅ Optimally Designing and Installing IKEA Metod Kitchen Units with Corner Solutions
Created on: 31 Mar 2023 08:17
Britle
Hello everyone, I am currently planning my new kitchen using IKEA Metod and am facing the challenge of designing the kitchen run with an optimal corner solution to maximize space while keeping everything functional.
I am particularly interested in which corner cabinets, pull-outs, or possibly carousel options work best combined within a Metod kitchen run to ensure both storage capacity and good accessibility.
Additionally, I would like to know the best way to handle the installation and assembly of the corner solutions, especially regarding stability and attention to detail.
So far, I have read that the interlocking of cabinets and careful planning of the panels are very important, but concrete tips are often missing.
Has anyone here already gained practical experience with planning and assembling IKEA Metod kitchen runs with corner solutions and can offer hands-on recommendations?
Britle
1 Apr 2023 15:02
RETRAVIS schrieb:
Inaccurate angles not only cause visual defects but can also significantly affect the functionality of the doors.
Thanks for the tip, I was aware of that but didn’t expect how much even a small error stands out here.
Jeanbar schrieb:
I have placed a corner carousel as well as a pull-out cabinet next to the corner. This makes the usage more flexible.
How did you organize that in practice? Are there any recommendations for the minimum width of cabinets next to the corner? I want a finely tuned setup, with smaller items in the pull-out and bulkier things in the corner cabinet.
Also, I’m interested if installing corner solutions can really be done alone, or if you need help with that, for example due to the weight and alignment.
GiRoyce
2 Apr 2023 08:29
For planning corner solutions with IKEA Metod, I can add that thorough preparation when measuring is essential: be sure to check whether the walls are straight, as otherwise positioning the cabinets can be difficult.
For assembly, I recommend working with a partner, especially for corner cabinets and carousel systems, not only because of the weight but also for precise alignment and securing. These systems have moving parts that can be damaged if installed incorrectly.
Another tip: additionally use construction adhesive or silicone at the joints of the countertops to ensure a strong and durable bond.
Finally, it is advisable to align all cabinet doors and drawers before final fastening to guarantee smooth operation.
KIN42
2 Apr 2023 10:41
Regarding the optimal corner solution for IKEA Metod kitchens, I recommend the following approach:
- Use a corner carousel only if there is enough space for the turning radius.
- A LeMans pull-out is helpful when maximum accessibility is required.
- Next to the corner cabinet, use pull-out cabinets with standardized widths for a clean, uniform look.
- Measure cover panels precisely and add small side panels if needed for a perfect finish.
- Plan for a second person during installation, especially when fitting corners and countertops.
This way, the corner solution can be both functional and stable.
