ᐅ Optimally Designing and Installing IKEA Metod Kitchen Units with Corner Solutions
Created on: 31 Mar 2023 08:17
Britle
Britle
31 Mar 2023 08:17
Hello everyone, I am currently planning my new kitchen using IKEA Metod and am facing the challenge of designing the kitchen run with an optimal corner solution to maximize space while keeping everything functional.
I am particularly interested in which corner cabinets, pull-outs, or possibly carousel options work best combined within a Metod kitchen run to ensure both storage capacity and good accessibility.
Additionally, I would like to know the best way to handle the installation and assembly of the corner solutions, especially regarding stability and attention to detail.
So far, I have read that the interlocking of cabinets and careful planning of the panels are very important, but concrete tips are often missing.
Has anyone here already gained practical experience with planning and assembling IKEA Metod kitchen runs with corner solutions and can offer hands-on recommendations?
RETRAVIS
31 Mar 2023 09:42
For an optimal design of IKEA Metod kitchen units in corner areas, I recommend first measuring the available space precisely and carefully evaluating the corner cabinet options in terms of their storage capacity.
The Metod series offers, in addition to classic corner cabinets, corner carousels and so-called LeMans pull-outs, which utilize corner storage space more effectively while improving accessibility. The LeMans system has the advantage that the shelves can be fully pulled out. Corner carousels, on the other hand, rotate to provide quick access but require a bit more clearance for rotation.
During assembly and installation, precise alignment using a spirit level and stable connections with galvanized corner brackets are essential. Panels should be cut to fit accurately to avoid gaps and maintain a clean overall appearance.
For stability, I recommend especially reinforcing corner cabinets with additional fixing points to each other and to the wall. The IKEA assembly instructions are clear, but I also suggest supplementing them with video material from experienced cabinet makers to understand the finer details.
geralu
31 Mar 2023 11:03
Corner solutions with Metod work well with LeMans pull-outs or corner carousels. Important: Cabinets should be properly aligned and secured with corner connectors. Panels must fit precisely. That’s all you need for the installation.
Jeanbar
31 Mar 2023 15:27
Hello Britle, I recently designed and installed my Metod kitchen with a corner solution. It’s important to consider the workflow in the kitchen, meaning how you want to use the storage space.
In addition to a corner carousel, I also placed a pull-out cabinet next to the corner. This makes the usage more flexible. Be sure that the corner cabinets are installed at a perfect right angle, otherwise you may encounter issues later with the doors and panels.
One more tip for assembly: use the metal brackets and dowels from IKEA, as they provide stability and prevent shifting. Once the cabinets are aligned, you can use panels to perfectly finish the look of the space.
If you like, I can also send you some measurements and details from my plan.
RETRAVIS
31 Mar 2023 18:51
Jeanbar schrieb:
Make sure the corner cabinets are installed at a perfect right angle; otherwise, you will have problems later with the doors and panels.
This is a crucial point. Inaccurate angles not only cause visual defects but can also significantly affect the functionality of the doors. Precision is especially important with corner carousels, where the direction of rotation and the clearance to adjacent cabinets must be correct.
Furthermore, I recommend fixing the left and right sides of the corner cabinets first during installation and only attaching the panels afterwards. This way, you can still make adjustments if needed.
JONSON
1 Apr 2023 09:16
Another important aspect when designing kitchen units with corner solutions using IKEA Metod is choosing the right countertop joint, especially at the corner.
When connecting two countertop pieces, it is essential to ensure the joint fits precisely and is secured with suitable clamps. Differences in height or uneven seams can significantly affect the overall appearance.
From personal experience, I recommend using special corner connectors for the joint if available, or reinforcing the connection with a stable substructure. However, IKEA’s assembly instructions on this matter are rather brief.
Additionally, the decision whether to use a 90-degree corner cabinet or an L-shaped solution should be based on the kitchen’s layout and how it will be used.
