ᐅ Cut parquet flooring lengthwise
Created on: 31 Mar 2020 14:56
X
X_SH5_X
X
X_SH5_X
31 Mar 2020 14:56
Hello everyone, which saw is best for cutting parquet lengthwise? Usually, the long edges are covered by baseboards, but I have a floor convector along which I need to lay the parquet lengthwise. A cut with a jigsaw doesn’t look good in this case. The problem is that the parquet is 220cm (87 inches) long. What kind of tool would you recommend? I was considering a circular saw or a table saw, preferably with a long guide rail (if such a size even exists).
Do you have any other tips? Thanks
Vicky Pedia31 Mar 2020 15:25
A circular hand saw is definitely the right choice. Almost every well-known manufacturer offers a guide rail as an accessory, which the saw is placed on to automatically maintain the correct cutting line. Your local tool rental service or hardware store should have something like this. Always use a new blade and test the cutting quality on a scrap piece beforehand.
X
X_SH5_X
31 Mar 2020 15:30
Ok, I thought so.
My father-in-law still has a table saw. Would that work as well? He says no, but if you have a suitable guide rail, it should be possible, right?
Vicky Pedia31 Mar 2020 15:32
A table saw will probably work as well, as it usually comes with a built-in rip fence. Alternatively, you can mark the measurements yourself and have it cut by a carpenter, who will have the appropriate tools.
halmi
31 Mar 2020 16:47
With the table saw, make sure the blade is not too coarse.
Bookstar
31 Mar 2020 16:50
Track saw with guide rail
