ᐅ Parquet Flooring on Underfloor Heating – Is Thermal Resistance a Concern?
Created on: 24 Feb 2018 21:17
blaupuma
blaupuma24 Feb 2018 21:17
We are planning to have oak parquet flooring installed. Today, at the specialist store, we were advised to have the flooring glued down. This supposedly eliminates the need for insulation and is better for underfloor heating. In general, parquet is not ideal for underfloor heating (the heat does not transfer as well as with other floor coverings).
Has anyone had extended experience with this? What should be considered?
By the way, the installation is supposed to cost 30 euros per square meter (about 3.3 square feet) [emoji15]—15 euros for the installation and 15 euros for the adhesive.
Thank you very much for your input.
Knallkörper
24 Feb 2018 21:44
The installation costs are normal to affordable. When designing the underfloor heating (installation spacing), the type of parquet flooring must be taken into account. In principle, this is not a problem. Gluing the flooring is always higher quality than floating installation.
RobsonMKK24 Feb 2018 22:30
We have 16mm (5/8 inch) oak parquet here. No problem at all, comfortably warm. But I would never want to skip gluing it down. Just the feeling of walking on it makes all the difference.
Baumfachmann
24 Feb 2018 22:32
In any case, glue it.
The price is acceptable.
Arifas25 Feb 2018 09:02
With us, installation will also cost 30 Euros. So I think that’s normal as well.
Specki
25 Feb 2018 09:25
Is the adhesive really that expensive? I mean, if you were doing it yourself, would you also pay €30 per m² (around $32 per sq ft) just for the adhesive?
