ᐅ Control two light sources alternately with a single switch?
Created on: 27 May 2018 10:53
mettbertI found it a bit difficult to choose a subject line, so I’ll try to explain my problem here:
In my bathroom, I have a light switch, but I want to control two different light sources or circuits alternately with it. The problem is that there is only a three-wire cable installed. Here is my desired setup:
First press: Light 1 and 2 turn on
Second press: Only Light 1
Third press: Only Light 2
Does anyone have an idea if there is an (intelligent) control device that I can simply connect in between? Or if such a thing doesn’t exist, maybe some kind of actuator that I can control separately when the power to the lights is on?
Thank you very much for your help or suggestions.
