ᐅ Construction Report Single-Family Home €1200 per m²
Created on: 14 Jun 2020 12:05
hegi___
This is the construction report following an earlier thread on floor plan design.
Planned are:
618 m² (6650 sq ft) plot of land
150 m² (1615 sq ft) living space
50 m² (540 sq ft) double garage
Air-to-water heat pump with underfloor and wall heating
Zehnder ventilation system
Exterior blinds in the living room, kitchen, and gallery. Windows anthracite on both inside and outside
Smart home wireless Homematic IP
Planned budget: €300,000 including land and ancillary costs + €30,000 reserve
Plus €12,500 net for a 9.6 kWp photovoltaic system financed separately
Only small regional companies recommended by other builders are being considered.
So far, the following trades have been contracted:
Earthworks: €20,000
Shell construction: €73,000 + €1,000 for the porch above the front door, Wienerberger Poroton T9
Roof: €19,000 + €1,500 scaffolding
Electrical work: €11,000 excluding chiseling work
Window materials: 17 Salamander triple-glazed units + Beck & Heun roller shutters + 5 Selt exterior blinds = €16,000
Quotes received for:
Plastering without decorative finish: €21,000
Bathroom ceramics Villeroy & Boch: €3,000 from Reuter Bathroom Shop
Interior doors Herholz: €2,600
Hörmann front door + garage door: €3,000
Building services materials from the internet: €10,000
Zehnder ventilation unit ComfoAir Q350 TR enthalpy heat exchanger including materials: €4,000 from Selfio
Nobilia kitchen furniture: €5,500, Bosch Series 4 kitchen appliances from Für Uns Shop with 50% discount for €3,500
Modern white villa with dark pitched roof, carport, two cars and front garden.
3D visualization of a modern white house with grey roof, garden and driveway.
Floor plan of a house with kitchen, office, hallway and WC as well as color-coded wiring.
Floor plan of a house with bedroom, child 1, child 2, dressing room, hallway, bathroom and stairs.
Architectural plan: two-story house with floor plans, sections and elevations.
Architectural plan of a house with front, rear, north and south views including measurements.
Construction cost breakdown with land, interim and building costs as well as own work.
hegi___
13 Feb 2021 14:07
tomtom79 schrieb:
Since you often read about humming noises in houses and then see an air-to-water heat pump mounted on the wall, I would avoid that. The same applies to indoor installation without a proper base.
Of course, the heat pump is decoupled using rubber vibration isolators. The same applies to the pipes, which are all exclusively separated from the building structure through insulation.
I have paid great attention to acoustic decoupling for all the pipes.
knalltüte
13 Feb 2021 14:18
hegi___ schrieb:
Last night, the circuit breaker on the construction power distribution unit tripped. The cable reel, which the insolvent construction company kindly left behind along with their scrap and work materials, burned out.
Then the heat pump, of course, completely froze up...
Not really needed anyway...
Just yesterday, when the screed was supposed to be heated.
Now I need several days to raise the temperatures inside the house again.
Would it maybe make sense for you to also use construction dryers there? Can you now comply with the specified screed heating schedule?
Tassimat
13 Feb 2021 14:22
I’m not very familiar with heat pumps, so please excuse a basic question:
What happens during a power outage lasting a few hours? Does a heat pump not automatically restart by itself, and could it potentially freeze up?
hegi___
13 Feb 2021 15:08
We also use dryers, but below 15°C (59°F) they are not very effective. The heat pump is now running at 8 kW, but it takes time for the entire mass to warm up again.
Normally, the pump restarts immediately, but after a certain period it simply freezes up. Then you are out of luck. The same applies if it were to fail at night during these low temperatures.
daniel1985ffo
16 Feb 2021 08:32
You definitely cannot achieve the required temperatures for screed heating with just a heat pump. We also have a heat pump from Alpha Innotec.
However, a mobile boiler was added and connected to the heating system for the screed heating, which provided an additional 21 kW.
It ran for 6 weeks. Without the heat pump alone, we would not have reached the necessary temperatures.
Regarding mounting the heat pump on the exterior wall of the house, every plumbing company advised us against it because of the humming noise.
Ours is installed 50 centimeters (20 inches) in front of the house on a concrete base, and even there the humming noise at full load is enough for me.
O
Osnabruecker
16 Feb 2021 08:34
daniel1985ffo schrieb:
Ours is installed 50 centimeters (20 inches) in front of the house on a concrete base, and even then, the humming at full load is enough for me.
The last few days, everything has been beautifully covered in snow, everything moves a bit slower, and you only hear the crunching of footsteps in the snow... and the rattling of heat pumps at -15°C (5°F) 😉
