ᐅ Column cladding in living and dining room
Created on: 15 Apr 2020 15:04
Abstall
Abstall
15 Apr 2020 15:04
we have two round columns in the living and dining area with a diameter of 16.5cm (6.5 inches) that I would like to cover smoothly and paint white. Does anyone have suggestions on the best way to do this? Or maybe some pictures showing how the base was finished on the floor with tiles, like in the example below?
Innenraum einer Baustelle: Mann mit Werkzeug, gelbe Eimer, hängende Kabel von der Decke.
Baustelle: Innenraum mit Gerüst, gelben Eimern, Baumaterialien, Blick nach draußen.
Thanks a lot
Andrea
guckuck2
15 Apr 2020 15:57
Just paint them.
Place the tiles closely together and seal the edges either with a silicone joint or a cover plate.
Abstall
15 Apr 2020 16:41
guckuck2 schrieb:
Just paint it.
Lay the tiles closely together and finish either with a silicone joint or a rosette.
Painting is a good idea, but the column isn't completely smooth. I would rather cover it... but with what? Styrofoam? You would see every dent if someone bumps into it...
guckuck2
15 Apr 2020 16:48
Then either sand it or apply filler and sand it afterwards, then prime it.
You will definitely need a painter for that who can do more than just whitewash wallpaper. It will also cost a few euros.
Abstall
15 Apr 2020 17:35
They have already been sanded, but there are still some small bumps remaining... I was thinking more of a cladding.
Mycraft15 Apr 2020 17:51
A painter knows what to do to achieve a smooth and flawless finish, including with special effect colors. I would also have it painted and leave it at that.
