we are now starting to seriously plan the carport and I’m wondering what the real downsides of a DIY store carport are.
About a month ago, we assembled two garden sheds from a DIY store and so far we are not disappointed – of course, the walls are a bit thinner, the wood is still drying, etc., but they look nice (thanks to paint) and serve their purpose.
Does anyone here have a carport from a DIY store? I often read about carport prices beyond 8,000€ – at the DIY store, the kit costs maybe 1,500€ (already a somewhat higher quality one).
So far, we have contacted a master carpenter who, despite an initial meeting, never provided a quote.
Good luck!
Good luck!
BeHaElJa schrieb:
Yes, I looked at that too – unfortunately, it’s a bit narrow for us.
How many people did you have for the assembly? @CurlyOurs measures 3.97m (13 feet) by 7.08m (23 feet). My husband and I set it up ourselves; it wasn’t difficult.
Sabine
Usually, you can build a carport yourself without needing a specific kit. Just look up the construction method online or at a hardware store, and then customize it to be larger if needed.
You can get the materials from any local timber supplier. It’s also a good idea to ask them if they can assist you with choosing the right materials.
My dad has built 5 carports himself, and even after 15 years, they are still standing strong. The wood is still in great condition.
So, we just visited the hardware store/building center and got some advice.
The consultant explained the structural differences between the store brand and Scheerer.
He calculated the cost for a Scheerer carport with an aluminum roof, 4 x 9 meters (adjusted to 3.6 m x 9 m) and one of the store brand with a wooden roof (3.6 m x 9 m as standard), both including a storage room; he would not recommend the aluminum roof for the store brand. Both are made of glued laminated timber.
nelly190 schrieb:
A carport can usually be built by yourself without an extra kit. Just look online or at a hardware store for the building method and then customize it to make it larger.In most cases, a building permit / planning permission is required for carports, which means structural engineering approval is necessary. If you can provide that individually, of course it’s possible. However, when making such statements, it’s important to keep in mind that in Germany there are many “DIY experts” who might read comments like the above and simply copy them.
Of course, this can be done – but it should be noted that getting a permit afterwards is always more expensive than asking beforehand.
Dirk Grafe
Dirk Grafe schrieb:
A building permit / planning permission is usually required for carports, which means you also need structural engineering documentation. It is, of course, possible if you can provide this individually. However, when making such statements, you should be aware that there are enough “DIY experts” in Germany who read this and simply copy it.
Of course, you can do that – but it should be added for information that retroactive approval is always more expensive than asking beforehand.
Dirk GrafeI never said building without a permit was allowed. You need one anyway. Overall, you should also feel confident enough to handle it yourself and apply for it accordingly if necessary.
