ᐅ Is it safe to assemble Ikea BESTA furniture using alternative screws or connectors?
Created on: 31 Dec 2023 09:37
mekadiHello everyone,
I am currently considering assembling some IKEA BESTÅ furniture pieces at home. Unfortunately, I don’t have the exact original screws and fittings from IKEA on hand at the moment, and would only be able to use alternative screws and connectors from a hardware store.
My question is quite specific: Can I safely assemble IKEA BESTÅ furniture using alternative screws or connectors without compromising the stability, load-bearing capacity, or long-term durability of the furniture? Are there particular types of screws or materials that are especially suitable or unsuitable? And do you have any experience with substitute components for IKEA’s specific connection systems in this furniture line?
My main concern is to ensure the furniture does not wobble or loosen over time and that the material is not damaged.
I look forward to your feedback, including any recommendations for alternatives that have proven reliable.
Thank you in advance!
Hello mekadi,
First of all, here is some basic information about screws and fasteners for the IKEA BESTÅ series:
- The BESTÅ series uses specially sized cam connectors (cam locks) and wood screws designed to work well with particleboard or MDF panels.
- Alternative screws might work, but you must make sure they are not too thick or too thin.
- The length and material of the screws are crucial — screws that are too long can split the material, while screws that are too short won’t provide a secure hold.
An important tip: If you want to replace the cam connectors, pay attention to the exact size (usually 15 mm (0.6 inches) in diameter) and the correct recess depth. Some aftermarket cam connectors are available from hardware stores; these should be made of high-quality metal, ideally galvanized to prevent rust.
If you choose to use wood screws instead, I recommend screws with a countersunk head and coarse thread designed for particleboard (e.g., SPAX particleboard screws). This will provide better anchoring without damaging the wood.
Summary:
- Alternative screws and connectors can be used as long as they match the dimensions of the original parts.
- The quality and material of alternatives are essential for structural stability.
- Be careful with screw length and thickness.
I hope this helps! If you like, I can also suggest some example products from hardware stores that I have successfully used myself.
Summary:
fredle schrieb:
Alternative screws and connectors are possible, provided they match the dimensions of the original parts.That's exactly right. Just make sure to choose the appropriate size and material. For BESTÅ, particleboard screws are recommended. Original cam locks, however, often remain the best choice.
Nathanaelk2 Jan 2024 17:59Hello mekadi,
I want to address your concern in more detail because there are some technical nuances that can easily be overlooked.
IKEA BESTÅ furniture is usually made from various wood-based materials like MDF or particleboard with a decorative layer. These materials have a certain compressive strength but are not designed to hold screws that are infinitely strong or to withstand excessive force.
- First, the load capacity of the screw connection in the wood-based material must be respected. This means that the screw needs to have an appropriate diameter (usually 4 mm to 5 mm) and sufficient thread depth in the material.
- The cam fittings also introduce a type of clamping force, where the rotating mechanism presses the furniture parts together. If you use low-quality material here, the clamping force will not be sufficient later on, and the connection will quickly loosen.
- Alternative cam fittings can work in principle, as long as they are compatible with the hole size and cam dimensions. However, precise fit is crucial.
- Screws with incompatible heads (e.g., not countersunk or too small a head) can cause problems during assembly.
- Particularly critical with alternative screws is the quality: cheap screws made from low-grade steel may rust or break.
My recommendation if you absolutely want to use alternatives:
- Measure the original fasteners precisely down to the millimeter.
- Use high-quality chipboard screws with countersunk heads.
- For cam connections: try to buy compatible metal cam fittings with a good fit.
- Use a torque wrench to avoid over-tightening the screws and damaging the material.
I’d also be interested in some details: Which exact piece of furniture do you want to build? How will it be loaded? Will it stand against a wall or free-standing? This affects the requirements for the screws and connections.
I hope this helps!
I hope this helps!
