Hello everyone, I have a question regarding the METOD kitchen cabinets from IKEA: I already own METOD fronts, which I generally like, but the color or finish no longer fits my new interior design concept. Therefore, I would like to know if it is easy to repaint the existing METOD fronts myself without damaging the surface or causing the paint to not adhere properly. I am particularly interested in any preparatory steps (sanding, priming), recommended types of paint, as well as advice on durability and the final result. Does anyone know if there are any specific characteristics of the METOD fronts that need to be considered when repainting? Thank you in advance for your experiences and tips!
As additional information: METOD fronts are usually made from coated MDF or particleboard with a melamine or foil surface. These surfaces are very smooth and non-porous, which makes painting difficult. Therefore, sanding with fine-grit sandpaper (e.g., 220 grit) is essential. A primer designed for plastics is recommended, such as a bonding agent for paints on coated surfaces. Acrylic or two-component (2K) paints are well suited for this type of painting. Durability largely depends on the preparation; if done correctly, the new paint layer can last several years.
Hello sinbrice, I would recommend thoroughly cleaning the METOD fronts before painting to remove any greasy or dirty residues, preferably using a mild cleaner or isopropanol. Then, lightly sand them—not too much to avoid damaging the surface—using sandpaper with a grit of 220 to 320, depending on how smooth you want the surface. After that, it’s essential to use a special primer designed for melamine or foil surfaces.
Regarding the paint itself: acrylic paint is a good choice because it has low odor and is flexible. Two-component (2K) paints are more durable but require experience and safety precautions during application. Spray applications usually provide the most even finish, but rolling is also possible if you use a fine paint roller.
I’m still wondering: what type of front surface do you have exactly? Smooth foil, high gloss, matte painted? This can affect the approach.
Surela schrieb:
I’m still wondering: What exact front surface do you have? Smooth foil, high gloss, matte lacquered? This can change the approach.Thanks for the tip! My fronts are matte foil-coated, not lacquered surfaces. Therefore, I assume adhesion is more difficult than with lacquered fronts? That confirms my idea to sand well and use a primer. It would be great if someone could share specific product recommendations for primer and paints suitable for matte foil-coated METOD fronts.
sinbrice schrieb:
It would be great if someone could share specific product recommendations for primer and paints for matte laminated METOD fronts.For matte laminated METOD fronts, I recommend a specialized 2-component plastic primer, which can be found at specialty retailers. For the paint, a water-based acrylic paint with high scratch resistance is suitable. Make sure to choose products with good flexibility to prevent cracking. It is important that the primer and paint are compatible—ideally from the same product line. Additionally, clean the fronts with isopropanol before painting and work in a dust-free environment.
