ᐅ How can I custom paint Ikea Metod cabinets?
Created on: 29 Apr 2021 14:12
O
owenpa
Hello everyone, I am currently looking into how I can custom paint my IKEA Metod kitchen cabinets to give them a more personalized appearance. The surface of the doors is often coated and quite smooth, so I’m wondering: what preparation is necessary to achieve a durable and even paint finish? Do I need to sand the doors, use a primer, or is one type of paint better than others? I’m also interested in which techniques are recommended – brush, roller, or spray application? And regarding the paint itself – should I use acrylic or alkyd paint, or is there a better alternative specifically for Metod cabinets? I look forward to your experiences and tips, as it’s a difficult decision for me and I want to avoid as many mistakes as possible.
lomin
29 Apr 2021 17:10
owenpa schrieb:
Could you possibly explain in more detail why a plastic adhesion primer is necessary?
Yes, that is really important. The surface of Metod doors is often very smooth and usually made of melamine resin-coated particle board or something similar. Without a primer, the paint would hardly last in the long term because it simply does not adhere well and tends to peel off easily. The plastic adhesion primer ensures a better bond between the smooth surface and the paint.
It is also important that the primer remains flexible, as the doors can move slightly due to temperature and humidity changes; otherwise, the paint may crack. Regarding 2K paints versus acrylic paints: I have worked with 2K myself—it is a hardener and resin-based system, very durable, but requires experience and safety precautions due to the chemicals involved. For DIY enthusiasts, acrylic paint is often easier to handle because it is water-thinnable, less toxic, and simpler to apply. There are high-quality acrylic paints available that are perfectly suitable for home use.
BeAndrea
29 Apr 2021 17:43
I would like to add my own experience: The right temperature and humidity are also important when painting – ideally between 18 and 22 degrees Celsius (64 and 72 degrees Fahrenheit) and not too humid.
PAR63 schrieb:
After drying, very fine sanding with 320 grit sandpaper
- Painting with acrylic paint in the desired color, preferably with a spray gun
I can only confirm that! Especially the intermediate sanding ensures a very good final result. Personally, I have always used a good spray can so far, since I don’t own a spray gun, and I believe with some practice, it can turn out really well.
When choosing the paint, I recommend going for a matte or satin finish, as it looks more premium and doesn’t show fingerprints as quickly. If you prefer a glossy finish, unfortunately, it requires more cleaning.
O
owenpa
29 Apr 2021 18:05
BeAndrea schrieb:
Intermediate sanding in particular ensures a very good final result.
That makes sense, as I assume that without intermediate sanding the surface will be too rough and the final paint layers might appear uneven or blotchy. How much sanding is typically required? Is it sufficient to lightly sand the dry paint surface once using very fine sandpaper, like 320 or 400 grit? Or are multiple sanding steps necessary? Also, are there any tips for minimizing dust during the painting process?
Garry
29 Apr 2021 18:37
Dust control is extremely important, so the following applies:
- Thoroughly wipe the workspace with a damp cloth before painting to bind dust
- Sand only with appropriate sandpaper, then wipe the surface with a damp cloth or an alcohol-based cleaning wipe
- Afterwards, keep the room as dust-free as possible, ideally by reducing window ventilation and selecting a low-dust environment if possible
For intermediate sanding: A light pass with 320-grit or finer sandpaper is sufficient. The goal is to remove minor imperfections and create a smooth surface for the next coat, not to remove the entire layer.
flo-Theres
29 Apr 2021 19:05
An additional note on color tone: I have had good experience with spray paints specifically designed for furniture. These are formulated for durability, scratch resistance, and consistent color tone.
If you want a more customized look, a combination of base and effect coats can be interesting. For example, a primer and base coat from a durable acrylic paint system, topped with a matte effect coat that creates a velvety surface. This is usually best applied at home using a spray gun, as the layer thickness needs to be carefully controlled.
AMELIE
30 Apr 2021 09:15
I would like to address a detail that is often overlooked: The edges of Metod doors are usually well-defined and quite sharp. These areas tend to accumulate paint and dust more easily. Before painting, I recommend gently sanding the edges with rounded motions. This not only improves the final appearance but also helps the paint adhere better, as sharp edges can cause chipping.
Additionally, if you remove the doors and paint them lying flat, you can avoid drips. Make sure to carefully check the hinges afterward to prevent any damage to the doors after painting.
