ᐅ Is it possible to plan and assemble an Ikea PAX wardrobe unit myself?
Created on: 29 Jun 2020 08:23
JupopiHello everyone, I am currently planning to build a wall unit for my living room and am considering using the IKEA PAX system for this. My question is: Can I really design a wall unit myself with IKEA PAX and assemble it independently without needing professional help?
I understand that PAX is primarily intended for wardrobes, but I am attracted by the flexibility of the system, as I want to combine different components such as shelves, drawers, and hanging rails individually.
I have some basic DIY skills, but I would like to know if custom sizes or special modifications are even possible with PAX, and how complex the assembly and planning are for a fully closed wall unit of living room size.
Does anyone have experience, tips, or advice on what I definitely should expect with a project like this? I am especially interested in stability and wall mounting, particularly when building a larger area. Thanks in advance for your insights!
Jupopi schrieb:
Can I really plan an IKEA PAX wardrobe system myself and assemble it independently without relying on professional help?Yes, that is generally possible. With the IKEA PAX planner, you can configure the wardrobe system yourself. When assembling, you should follow the instructions carefully and allow enough time. For larger wardrobe units, wall mounting is essential to increase stability.
Jupopi schrieb:
I am aware that PAX is actually designed for wardrobes, but I am attracted by the flexibility of the systemThe PAX system is indeed very flexible and suitable for various storage purposes, but there are a few technical aspects you should consider.
- The height of the units typically comes in 201 cm (79 inches) or 236 cm (93 inches); IKEA does not offer custom sizes. For a large wardrobe wall exceeding these dimensions, you would need to arrange multiple modules side by side or stacked, which increases stability requirements.
- The IKEA PAX planner is very helpful, but budgeting and dimensional accuracy must be checked carefully. Small measurement inaccuracies can lead to problems.
- Regarding installation: all units must be securely fixed to the wall. For a large wardrobe wall, I recommend investing in a wall-mounting solution capable of withstanding high loads.
- Assembly is generally manageable with some DIY skills, but the effort and time required are higher than for a simple wardrobe.
If you like, I can give you some tips on how to prepare the process step by step to minimize errors. It is also worth considering whether to use additional reinforcements (e.g., wooden battens for wall mounting).
TYRELL schrieb:
All cabinets must be securely fastened to the wallThis is an important point that should not be overlooked.
In addition to wall fastening, you should make sure that the substrate is suitable. With drywall, the load is often critical, as special anchors or additional reinforcements are required. The stability of the entire cabinet wall depends greatly on proper installation.
Furthermore, custom sizes are not available for PAX, which you should consider carefully, as adjustments with cuttings are only partially possible and may affect warranty coverage.
If you are planning a sophisticated interior layout, the appropriate IKEA interior fittings are recommended – the modular inserts provide a well-thought-out and clean solution.
Here is a brief guide with tips and tricks for planning and self-assembling IKEA PAX as a built-in wardrobe system:
1. Planning:
- Draw the available space including windows, doors, and electrical outlets.
- Measure the wall width and height precisely, as PAX offers modularity in width and height (width modules are usually 50 or 75 cm (20 or 30 inches)).
- Use the IKEA PAX planner online to select modules and check combinations of open compartments, drawers, and hanging rails.
2. Preparation:
- Purchase all parts in advance to avoid issues with missing components on site.
- Ensure you have enough space for assembly and helpers to hold and install parts.
3. Assembly:
- Follow the IKEA instructions step by step, take your time, and verify each step.
- Pay special attention to the correct orientation of all parts.
- For larger wardrobe systems, fix the modules to the wall progressively instead of just placing them side by side.
4. Wall installation:
- Use suitable wall plugs or anchors for the wall type.
- The wardrobe system must stand securely and closed; use additional fixings or reinforcements if necessary.
5. Finishing:
- Fill small gaps with silicone or decorative trim.
- Check drawers and doors for smooth operation.
Common mistakes include inaccurate wall measurements, lack of helpers, and rushing through the work.
If you like, I can provide a more detailed breakdown of the individual steps.
1. Planning:
2. Preparation:
3. Assembly:
5. Finishing:
Jupopi schrieb:
Does anyone here have experience, tips, or advice on what I should definitely expect with a project like this? I’m especially interested in stability and wall mounting, particularly if I want to build a larger unit.I planned and built a similar wardrobe wall with PAX myself some time ago. It is important that you:
- Make a detailed plan, including all measurements
- Pay attention to the maximum load capacity of the wall and use suitable fixing materials (e.g., metal expansion anchors or universal anchors for concrete walls)
- Use a second person to help with the installation
- Stay patient and follow step-by-step instructions carefully
One critical point for me was that the elements are very standardized, and sometimes a gap remains with custom widths. I used cover panels to visually compensate for this. For stability, wall mounting is essential, as PAX units can otherwise tip over.
