ᐅ Can I also add IKEA Komplement accessories to my Pax wardrobe?
Created on: 7 Jul 2018 18:17
chen38
chen38
7 Jul 2018 18:17
Hello everyone, I have a specific question regarding the use of accessories for my Pax wardrobe from IKEA. Is it possible to retrofit accessories from the Komplement series into my existing Pax wardrobe without issues related to fit or stability? I am thinking of adding drawer inserts, shoe racks, or clothes rails from the Komplement line to my wardrobe. Are there any experiences or tips on what to watch out for, and whether all parts are compatible—especially with older Pax wardrobe models? Thanks in advance for your opinions and advice!
dinano
7 Jul 2018 19:04
I find the question very clearly formulated, thank you for that. However, it is important to differentiate here: not only whether the accessories fit mechanically into the existing mounting points, but also whether the load capacity works properly.
chen38 schrieb:
Can I retrofit accessories from the Komplement series into my existing Pax wardrobe without encountering issues with fit or stability?
That is not always the case, as IKEA occasionally changes dimensions or fastening systems. Older models in particular could cause problems. Do you have the exact model name or the year of manufacture of your wardrobe? This information is important to determine whether the new Komplement parts are compatible or if, for example, they have different holes or spacing.
Additionally, I would question whether retrofitting these parts is intended by the manufacturer. Some components are specifically designed for certain wardrobe variants or sizes.
INGRID34
7 Jul 2018 19:45
In short: Most complement modules are designed for Pax and will fit. However, older models may have slight variations. It’s best to check in the local IKEA store or compare based on the dimensions.
klo40
7 Jul 2018 21:12
I would like to provide a more detailed guide on how to check if Komplement accessories will fit into an existing Pax wardrobe:
- First, accurately measure the interior dimensions and the installation spaces of the wardrobe (width, height, depth).
- Then technically measure the specific Komplement part (e.g., installation height of drawers, distances between mounting holes, depth of inserts).
- If something does not seem to fit, small aids such as spacers or screw adapters can often help.
- Important: Do not exceed the load capacity. IKEA provides datasheets for this, which can usually be found in the store or online.
A common mistake is confusing the depth: Komplement parts often come in two versions for 35cm (14 inches) and 58cm (23 inches) wardrobe depths. It is essential to be very precise here.
Summary: With careful measuring and planning, retrofitting usually works, provided the Pax wardrobe is not older than about 10 years.
Samir
8 Jul 2018 07:29
From a technical standpoint, it is important to note that the Komplement accessories from IKEA are specifically designed for the Pax system. Therefore, compatibility is generally ensured, but IKEA recommends using accessories only with the current Pax models.
Points to consider:
- Variations in older Pax models that may have different drilling distances or attachment methods
- Weight limits for drawers and shelves, which are specified both in the user manual and on IKEA’s website
- The cabinet depth, as Komplement accessories are produced specifically for certain depths (35 cm (14 inches) vs. 58 cm (23 inches))
My advice: Check the manufacturer’s specifications, take measurements, and clearly specify the accessories before purchasing.
noge58
8 Jul 2018 10:56
Great topic! I also added several items from the Komplement series to my Pax wardrobe, such as drawers and clothes hangers. It worked perfectly, and the quality is excellent! 😊 Just make sure to check the wardrobe depth (mine is 58 cm (23 inches)) and choose the matching parts.
My advice: Try testing or asking at your local IKEA store—they usually provide good help. And don’t be afraid of the installation; it’s quite straightforward!
