ᐅ Is it possible to secure the IKEA BRIMNES wardrobe to the wall?
Created on: 7 Mar 2020 19:36
Marbo
Marbo
7 Mar 2020 19:36
Hello everyone, I am planning to buy the IKEA Brimnes wardrobe and definitely want to secure it to the wall to ensure more stability and safety, especially with children in the house. My specific question is: Can I safely mount the IKEA BRIMNES wardrobe to the wall, and if so, what are the best fixing methods and materials to use? Are there particular screws, anchors, or brackets you would recommend, and are there special considerations to keep in mind, such as the type of wall (e.g., concrete, drywall) or the construction of the wardrobe? I would really appreciate practical tips and experience-based advice.
feklo
7 Mar 2020 20:14
Hello Marbo,
to answer your question: Yes, the IKEA BRIMNES wardrobe can generally be secured to the wall, and it is actually recommended to do so to prevent tipping hazards.
Here is a brief guide:
- IKEA usually provides wall mounting hardware with the wardrobe. These are designed to be used on various wall types.
- First, determine the material of your wall: concrete, brick, or drywall.
- For concrete or brick, heavy-duty anchors and screws are suitable (e.g., 6mm (1/4 inch) anchors with matching screws).
- For drywall, use special cavity anchors or metal anchors to ensure a secure attachment.
- It is important to place the mounting points on wall studs (in drywall installations) whenever possible.
- The included metal brackets are screwed to the top of the wardrobe and to the wall.
Always make sure that the screws and anchors can safely support the load without damaging the wall and that the wardrobe is not merely hanging on the wall. Having a second person hold the wardrobe in place helps during installation.
In summary: Yes, mounting is possible and recommended. But always check the wall first, choose the appropriate anchors, and use the included brackets if available.
kauti
7 Mar 2020 21:22
feklo schrieb:
- IKEA usually provides wall mounting hardware with the cabinet. These are designed to be used with different types of walls.
That is exactly the point. The BRIMNES wardrobe from IKEA is supplied with a minimum number of angle brackets intended to ensure safe wall attachment. The type of wall is crucial in choosing the appropriate fixing materials:
- Concrete/brick walls: Use standard heavy-duty wall anchors, at least 6 mm (1/4 inch) in diameter.
- Drywall (plasterboard) walls: It is recommended to reinforce the wall by locating the underlying framing (wood or metal studs) or use suitable hollow wall anchors.
- If in doubt, it is advisable to have the mounting checked by a professional.
Please observe the maximum load capacity of the anchors and always assemble the furniture according to the manufacturer’s instructions. Retrofitting additional fasteners can further improve stability.
Layla
8 Mar 2020 08:03
Marbo schrieb:
Can I safely attach the IKEA BRIMNES wardrobe to the wall, and if so, what fastening methods and materials are best suited for this?
I think it’s really important that you bring this up because safety is truly the main reason for securing furniture to the wall. I also have small children and can only confirm that wall mounting this wardrobe is not just sensible but necessary.
From my own experience, it helped to align the wardrobe carefully before securing it and even leave a small gap from the wall to make later adjustments easier. Most concerns about fastening come from uncertainty about the right tools and screws, but this quickly fades once you read up a bit or ask for advice here in the forum.
In addition, I would recommend regularly checking the wall fastenings, especially after some time has passed. This really gives you peace of mind that everything remains secure.
Hannes
8 Mar 2020 11:51
Yes, you should definitely secure the BRIMNES wardrobe to the wall. Use the supplied brackets and appropriate anchors, depending on the wall type.
Here is a brief guide on how to proceed:
- Mark drill holes on the wall
- Insert the anchors
- Fix the brackets with screws
- Screw the wardrobe onto the brackets
This will prevent tipping accidents. Done.
