ᐅ Power supply for countertop lighting?
Created on: 8 Dec 2013 11:29
aewag
aewag
8 Dec 2013 11:29
Hello, I am currently planning the mounting of my new IKEA Faktum wall cabinets and have realized with dismay that the back panel of these cabinets is flush with the side panels. Other manufacturers design the back panel recessed, allowing cables for under-cabinet lighting to be routed there. Although IKEA also offers under-cabinet lighting systems, I am puzzled about how the supply cables are supposed to be routed under the wall cabinets. Has anyone found a good solution for this?
IKEA-Experte
8 Dec 2013 14:19
After I once had mold stains on the back panels of some wall cabinets, I installed them with about a 1cm (0.4 inch) gap from the wall by placing wooden shims with holes onto the screws before hanging the cabinets.
With Metod, this problem will no longer occur.
aewag
8 Dec 2013 15:05
Thank you for the tip about the washers and the information on the new kitchen system METOD. I took a look at the new system on the Ikea website .dk. It’s great that Ikea has finally improved and simplified the wall cabinet mounting.
Maverick1854
10 Dec 2013 05:56
The idea of adding extra lighting was not very popular when Faktum was created. That’s why it didn’t / doesn’t exist yet...
But now everything will be fine
fotokatze
22 Dec 2013 16:18
Hello!
I have installed matching side panels on the upper cabinets—on the sides, bottom, and top. This not only improves the overall appearance of the cabinets, but also provides a convenient space to run the cables for the countertop lighting without any issues.
For this, I had a suitable groove milled (using a router) or cut (using a circular saw) into the back of the side panels by a local hardware store with an attached woodworking shop. With a width of about 15mm (0.6 inches) and a depth of around 5mm (0.2 inches), there is enough space to neatly hide plenty of LED wiring completely out of sight.
Fotokatze
