ᐅ Boundary Construction of a Double Garage/Carport 6x9m in Lower Saxony
Created on: 15 Dec 2014 10:05
Häusle77
for our new construction project, we would like to build a double garage or a double carport with a storage shed that has direct access to the house.
How is this regulated in Lower Saxony? A 6x9m (20x30 feet) boundary construction is allowed without the neighbor’s approval, right?
However, I think I heard that a maximum of 36 square meters (387 square feet) of usable area is permitted, and with 6x9m (20x30 feet), that would be clearly too much.
So what is correct?
So what is correct?
DerBjoern23 Jul 2015 12:24ypg schrieb:
In Lower Saxony?
Yep
Bau_Benni_4.013 Dec 2016 18:13Hello housebuilding forum,
I didn’t want to create a new thread just for this and hope someone can help me here.
I would like to know if I am allowed to attach a carport (5m x 6m) directly in front of my double garage (6m x 9m), which is positioned with its 9m side along the property line. The carport’s 5m side would also be right on the property boundary (in Lower Saxony).
Thank you in advance.
Regards, Bau_Benni_4.0
Bau_Benni_4.0 schrieb:
Hello dear house building forum,
I didn’t want to create a new thread just for this and hope someone can give me an answer here.
I would like to know if I am allowed to attach a carport (5m x 6m) directly in front of my double garage (6m x 9m), which is located with its 9m side on the property boundary, without any gap. The 5m side of the carport should also lie on the property boundary (in Lower Saxony).
Regards, Bau_Benni_4.0Check the Lower Saxony State Building Code (NDS Landesbauordnung); I think there is a 12-meter (39 feet) rule for all buildings on the boundary line combined.
Also, with a carport, the floor area ratio must not be exceeded.
Bau_Benni_4.014 Dec 2016 17:19Hello Yvonne,
thank you for your reply. If I understand the Lower Saxony Building Code correctly, I am not allowed to build a carport in front of or behind my garage, as it is already 9 meters long (30 feet). However, I assume I may be allowed to build a carport up to 6 meters (20 feet) long on another boundary line, making a total of 15 meters (49 feet). Is that correct? Or is it possible to apply for a building permit / planning permission to build the full 15 meters (49 feet) on one boundary, provided that there is no structure on any other boundary? Phew, this is really complicated...
§ 5 para. 8 Lower Saxony Building Code: Setback Distances
(8) No setback is required
1. Retaining walls, embankments, and enclosures in commercial and
industrial zones, outside these building zones, up to a height of
2 meters (6.5 feet), and
2. Buildings and enclosures in building zones where, according to the
development plan, only buildings with a garden courtyard enclosed
from external view are permitted, provided they do not exceed 3.5 meters (11.5 feet) in height.
Without setback or with a reduced setback of at least 1 meter (3 feet)
from the boundary are permitted
1. Garages and buildings without habitable rooms or fireplaces up to
3 meters (10 feet) in height, and
2. Solar installations that are not part of a building, up to 3 meters (10 feet)
in height.
Buildings according to sentence 2 may reduce the setback according to
paragraph 2 along a total length of 9 meters (30 feet) per property boundary,
but on a building plot, this reduction may only extend along one boundary
for a total length of 15 meters (49 feet). When applying sentences 2 and 3,
buildings built on the boundary without setback as described in sentence 2,
item 1, must be taken into account according to paragraph 5 sentence 2. When
applying sentence 1 item 2, paragraph 2 sentence 3 applies accordingly.
in height.
Yes, sorry, I could have given you this answer spontaneously as well (maximum 9 meters (30 feet) on one side), but I was a bit confused by the previous post.
9 meters (30 feet)!
A carport is included.
No, but it might be possible with a signed agreement from the neighbor... they have to give written consent.
9 meters (30 feet)!
Or is it possible to build 15 meters (50 feet) right up to the boundary with a building permit,
Bau_Benni_4.014 Dec 2016 19:49Ok, then I’ll try my luck with the neighbors and the authorities.
Thank you very, very much and see you next time...
