ᐅ Billy shelf: Tips on quality differences when ordering new units.
Created on: 3 Aug 2019 10:21
eddyben
eddyben
3 Aug 2019 10:21
Hello everyone, I am currently planning to replace my Billy bookcase with a new order. I noticed that there seem to be different quality levels and production locations, which vary in material thickness, workmanship, and stability. I am especially interested in hearing about your experiences with the different quality versions. Are there specific details to watch out for when buying to avoid getting a lower-quality model? For example, differences in the shelves, the back panel, or whether different screws and material thicknesses actually make a noticeable difference in stability? I want to avoid being disappointed after assembly if the bookcase does not offer the expected durability. Thanks in advance for any tips and advice!
FAZAR
3 Aug 2019 11:03
Hello eddyben, the question about quality differences in the Billy bookcase is actually not that simple. Over the years, IKEA has introduced some small variations in design and manufacturing that affect stability and durability. The most important factor is the thickness of the shelves. The standard version usually uses 16mm (5/8 inch) particleboard, while the more affordable version may have slightly thinner shelves.
There are also differences in the back panel: older models use continuous hardboard panels, which are a bit more stable, whereas many newer versions use pressboard, which is lighter but less sturdy.
The screws and fasteners have also changed over time—cheaper materials can wear out or break faster in humid environments or under heavy use.
A tip: when buying new, check the product number, as it often indicates which version is being sold online or in the store. If you plan to use the bookcase for heavy loads, additional wall mounting (IKEA offers suitable kits for this) can significantly increase stability.
Maybe you can tell me exactly what you want to use the Billy bookcase for? That would help me give more specific recommendations.
eddyben
3 Aug 2019 11:47
FAZAR schrieb:
A tip: When buying new, pay attention to the product number, because often it is indicated online or in-store which version is being sold.
Thanks for the detailed reply! I plan to use the shelf mainly for books and binders. The load per shelf will often be around 15-20 kilograms (33-44 pounds), sometimes a bit more. I will definitely install wall mounts, but I want to avoid the shelves sagging or drawers causing problems later. Can you provide more information about the shelves themselves – for example, are there different thicknesses and surface finishes? The back panel should also affect stability; are there any differences I can recognize when visiting the store? Thanks!
Bautau
3 Aug 2019 12:14
FAZAR schrieb:
The standard version usually uses 16 mm particleboard
For clarification: Standard shelves are generally 16 mm (0.63 inches) thick, but some newer models are only 12 mm (0.47 inches). This noticeably reduces the load capacity to about 20 kg (44 lbs) per shelf instead of up to 30 kg (66 lbs) for the thicker version.
The surface is coated with melamine resin and should be slightly moisture-resistant, but scratches can damage the finish. If stability is important, I recommend purchasing the thicker model or the version with steel support bars, which IKEA occasionally offers as optional accessories.
Regarding the back panel, it is often hard to tell in-store whether it is made of particleboard or hardboard just by looking, unless you are familiar with the smell or how it reacts to moisture. When in doubt, it’s best to ask IKEA customer service or specifically inquire about the model.
For bookshelves with load recommendations, the 16 mm (0.63 inches) version plus wall anchoring is recommended.
Z
zardi
3 Aug 2019 12:42
I have made sure with several Billy bookcases that the shelves are 16 mm (5/8 inch) thick and that the back panel is made of a solid, continuous board. This really makes a noticeable difference in stability.
Also important: align the shelves properly and secure the dowels correctly.
Don’t forget wall fixing!
Joe52
3 Aug 2019 13:20
Hello eddyben, I completely understand what you mean. Some time ago, I reordered my Billy shelf and was also unsure about the quality. In my experience, you just need to be much more careful during assembly, no matter which version you receive.
Sometimes the initial feeling right after assembling it can be disappointing, but the shelf usually holds up longer than expected. A bit of patience and calmness helps 🙂
Maybe this will reassure you a bit: Many members here in the forum recommend using wall mounting, which makes almost every version significantly more stable.
