ᐅ BILLY shelf squeaks despite maintenance – new rust or incorrect assembly?
Created on: 2 Dec 2021 19:27
mayk47
mayk47
2 Dec 2021 19:27
Hello everyone, I have a Billy shelf unit that still squeaks after thorough maintenance whenever I load the shelves or slightly move the unit. My question is: Could the noise be caused by newly developing rust on the frame or the fittings? Or does the squeaking indicate an assembly error? I have checked and tightened the screws several times; all parts seem to be properly assembled. Still, the unpleasant noise occurs and I can’t pinpoint its cause. Maybe someone has had similar experiences with BILLY shelves and can advise me on how to best identify the source of the squeaking? Thank you in advance!
Arianeo
2 Dec 2021 19:42
Hello mayk47, your issue sounds like one of the typical cases involving furniture with metal and wood components.
The squeaking can actually come from rust if water or moisture has reached the metal parts. Especially where metal meets metal or metal meets wood, rust can cause rubbing and squeaking noises.
However, incorrect assembly should not be ruled out. If screws are tightened too much or unevenly, parts may shift slightly under load, causing noises.
My advice: First, check whether all screws are properly and evenly tightened and if any moving parts are loose. Then you can carefully spray the metal parts with a rust remover if rust is visible. This will prevent further squeaking caused by friction.
If you like, I can also explain step-by-step how to inspect the shelf for typical assembly issues.
plopra
2 Dec 2021 20:07
Rust or incorrect assembly: First, check all screw connections and tighten them. Then apply silicone spray or graphite powder to metal contacts. This usually helps.
bupar
3 Dec 2021 08:16
For objective context: The BILLY shelf has a simple construction, usually combining particleboard with metal angle brackets secured by screws. Common sources of noise are either loose, insufficiently tightened screw connections or corrosion on the metal parts.
Rust formation is often superficial, caused by moisture exposure. At an early stage, this can already cause squeaking friction but has little impact on stability if treated promptly.
Incorrect assembly often shows as misaligned screws or excessive tension between parts, which also leads to noise. A systematic approach means:
1. Check the torque of all screws, avoid overtightening
2. Visually inspect for rust, especially on the metal brackets
3. Verify the correct fit of assembled parts
If all points appear fine, I would suspect rust as the cause, especially if moisture was involved in maintenance.
MUMENAR
3 Dec 2021 10:23
Arianeo schrieb:
If you like, I can also explain step-by-step how to check the shelf for common installation damages.
That would actually be interesting, as I think it’s a bit premature to assume rust is the only cause.
Incorrect installation doesn’t just cause noises but can lead to lasting material stresses that may increase over time.
If you have thoroughly checked the assembly instructions and original parts, the question remains: Could moisture have penetrated the shelf during maintenance, causing the wood to swell slightly? This can also cause squeaking due to changed friction conditions, even without rust being involved.
I would further differentiate by also considering the wood quality and storage conditions. Only this way can the issue be logically narrowed down.
klo40
4 Dec 2021 07:41
Hello mayk47, to assist you effectively, here is a brief guide for troubleshooting:
1. Visual Inspection: Check all screws and brackets for rust. Use a bright light and a magnifying glass if possible.
2. Tighten Screws: First, slightly loosen them, then evenly retighten all to relieve any tension.
3. Operation Check: Gently move the shelf and observe if the squeaking starts consistently at one specific point.
4. Mechanical Lubrication: Apply some graphite powder or a dry lubricant to the joints. Liquid oils may leave stains on wood.
If the noise persists, check for unintended tensile forces, for example caused by uneven floors or load distribution.
This helps avoid misinterpretation and leads to a precise intervention.
Hope this helps you narrow down the issue further.
