ᐅ BILLY Shelf Doors Are Sagging – How to Adjust Them?
Created on: 12 Mar 2023 08:47
Far10
Far10
12 Mar 2023 08:47
Hello everyone, I have noticed that the doors on my BILLY shelf from IKEA gradually sag over time. This not only affects the visual alignment but also causes the doors to rub against the bottom frame, making them sometimes difficult to open. I suspect it has to do with adjusting the hinges, but I’m not sure which screw needs to be adjusted and in what way to bring the doors back to the correct level. Has anyone had experience with readjusting the BILLY doors? If so, how exactly do you adjust the hinges to prevent the doors from sagging and keep them stable over time? I’m looking forward to helpful tips or a step-by-step guide, thanks in advance!
Tevin
12 Mar 2023 09:36
Hello Far10,
Well-phrased question! The sagging of BILLY shelf doors is indeed a known issue, usually related to the adjustment of the metal hinges that IKEA uses there. Basically, the hinges have three adjustment screws: one for the horizontal position, one for the vertical position, and one for the closing pressure.
To adjust the door height, that is to move the door panel up or down, you should use the vertical screw. This is usually located on the back of the hinge and has a Phillips head screw.
My tip: Open the door and loosen this screw only slightly (maximum half a turn), so you can raise the door a bit. Then tighten it again, test the position, and repeat the process if needed. Caution: If you turn it too much, the door may become too loose or get damaged.
Also, make sure that all screws are well tightened, as loose screws are often the cause of sagging.
If you like, I can also write a small step-by-step guide on how I adjusted the doors on my BILLY.
Good luck!
Jensson
12 Mar 2023 15:52
Hello Far10,
I would like to add a structured approach to door adjustment for the BILLY shelf, complementing Tevin’s answer:
1. First, open all the doors and carefully observe the hinges. BILLY uses Ergo hinges with typical adjustment options.
2. The vertical screw is usually the rear one of the three screws on the hinge. Use a Phillips screwdriver to gently turn this screw upward to raise the door.
3. The horizontal screw (at the front of the hinge) is used for lateral alignment – probably less relevant in your case, but it’s worth checking.
4. The third screw controls the pressure with which the door closes. It helps prevent rubbing but does not significantly affect the position.
5. After each small adjustment, open and close the door several times to ensure it fits properly and does not stick.
6. If you notice the door keeps sagging, check the attachment on the back panel of the shelf – loose dowels or pulled screws can also cause the problem.
7. If all screws are tight and the problem persists, replacing the hinges with stronger models may help. There are also small plastic washers that can be placed behind the hinges to fix the height.
Summary: The key is the vertical screw, which you need to adjust carefully. I recommend proceeding in small steps and checking repeatedly.
Tevin schrieb:
To adjust the door height, that is, to move the door panel up or down, you should use the vertical screw.
I can definitely confirm that. If you run into any problems while doing this, just let me know!
blapau
13 Mar 2023 10:19
One more important note: If your doors sag despite correct adjustment, it is often due to the hinge fixings in the wood or the dowels, which can loosen over time.
Often, the cause is that the screws feel tight but the wood material fatigues, reducing holding strength. In the case of a BILLY shelf, this can especially happen if the hinges are heavily loaded or exposed to high humidity.
My tip: Gently wiggle the door to check if the screws in the cabinet body are secure. If not, you can apply wood glue into the existing hole and insert a toothpick or wooden filler to fill the hole, allowing the screw to grip better again. After drying, remount the hinge and readjust.
Jensson schrieb:
If all screws are tight and the problem persists, replacing the hinges with stronger ones can help.
This is also my advice, but only after the fixings have been checked and reinforced. Often, properly securing the screws in the wood is enough to keep the adjustment stable.
baupau
14 Mar 2023 07:44
Turn the vertical screw at the back of the hinge.
Check the screws on the hinge and the shelf.
Repair any loose wood with wood glue and filler material.
Readjust and test.
This will help prevent sagging.
