ᐅ BILLY Shelf Colors Fading: How Can I Prevent It?
Created on: 25 Jul 2021 08:37
Gere65
Gere65
25 Jul 2021 08:37
I have a BILLY shelf from IKEA with a white lacquer finish that has gradually been fading over the past two years. The color fades especially in areas exposed to direct sunlight, but I wonder if there is any way to prevent this process so the shelf stays looking like new for longer. It has a melamine resin-coated surface, and I suspect that UV radiation is mainly to blame.
Do you have any experience or tips on how to prevent or at least slow down the color change on BILLY shelves? Are there any recommended cleaning products, protective films, or perhaps some kind of sealant that can reduce fading?
I look forward to your factual advice, preferably with some technical background if possible.
barle
25 Jul 2021 09:03
The best way to prevent fading is to avoid placing the shelf in direct sunlight whenever possible. If this is not feasible, using a UV protective film on windows or curtains can help. Additionally, be cautious with cleaning products, as harsh chemicals can damage the finish.
lorena
25 Jul 2021 11:54
Hello Gere65,
I would like to address your concern about the fading of the BILLY shelf in more detail. The BILLY shelf typically has a melamine resin-coated surface, which is quite resistant to scratches and many liquids, but it is not highly UV-resistant.
Regarding the exact mechanism: UV radiation causes the colorants and binders embedded in the surface to gradually break down, leading to changes in color perception and eventually fading. The coating itself can undergo microstructural changes, which enhance the duller and paler appearance.
How to prevent this:
1. UV-protective films on windows are very effective, as they filter out most of the UV radiation without significantly reducing daylight.
2. Keep the shelf away from direct sunlight whenever possible or use curtains/blinds to regulate the light exposure.
3. Avoid harsh cleaning agents or abrasive sponges. Mild soapy water or cleaners specifically designed for lacquered furniture are ideal.
4. Some recommend reapplying the surface with special UV-protective varnishes or clear furniture waxes that create a barrier against UV – however, be sure to test this on an inconspicuous spot first.
What I would still like to know: Is your shelf placed in a location with strong sunlight exposure, for example, directly by a south- or west-facing window? And how often do you usually clean it? This information will help tailor advice more precisely.
Benge5
26 Jul 2021 16:22
Gere65 schrieb:
This is a melamine resin-coated surface, and I suspect that UV radiation is mainly to blame.
The suspicion is correct. Melamine resin coatings provide good protection against mechanical wear but are not completely resistant to UV rays. Long-term fading occurs due to photochemical reactions within the coating.
To counteract this, several effective measures can be taken:
1. UV-blocking window films are the most effective preventive measure. A high-quality film with UV filtration greater than 99% is recommended.
2. Darkening with blinds or curtains during the day reduces UV exposure.
3. Avoid cleaning with solvents and alkaline cleaners, as these can damage the surface and make it more vulnerable to UV.
4. If technically feasible and desired, applying UV-resistant clear coats is an option—products based on polyurethane or acrylic should be selected. Important: match the type of coating to the material and follow the product datasheets.
In summary: There is no complete and simple solution without compromises. The best approach combines light-protective measures with careful maintenance.
If anyone has alternative experiences with other surface treatments for BILLY, a report here would be very helpful.
