ᐅ Assembling a BILLY shelf without instructions – are there any helpful tutorials?
Created on: 27 Mar 2018 14:07
Papeda
Hello everyone, I’m currently facing the challenge of assembling a Billy shelf from Ikea but no longer have the instruction manual. My question is: Has anyone ever assembled a BILLY shelf without the printed instructions and can recommend helpful tutorials or videos that clearly explain the process step by step? I’m especially interested in resources that also address common pitfalls, as I don’t want to waste time or make mistakes during assembly. Any help would be greatly appreciated!
mifra
27 Mar 2018 17:04
As a supplement: When assembling, pay attention to the correct orientation of the shelves. They often have an edge that should be visible at the front and a back side. This contributes to stability and appearance. Another tip: Some users recommend applying a small drop of oil to the metal pins before inserting them, which helps them screw in more smoothly and without jamming. This can make the assembly easier, especially without instructions.
luAlbert1
28 Mar 2018 10:22
I always wonder why anyone would start assembling BILLY without the instructions. Isn’t that a typical challenge to one’s comfort zone, where you end up spending more time than if you had just followed the manual? But well, if someone really wants to do it: In my opinion, people overestimate the difficulty. The shelf is simply designed, and with a bit of thought, you can manage a lot even without instructions. Still, to answer the question: tutorials are helpful but not absolutely necessary. However, if you are looking for quick solutions, you shouldn’t skip the tutorial.
Luke44
28 Mar 2018 11:05
It's best to approach the shelf step by step yourself. Attach the back panel first, then fix the side panels, and finally place the shelves. Tutorials are helpful, but often experimenting is the best way.
Papeda
28 Mar 2018 13:37
JEREMIAH38 schrieb:
There are some good assembly videos on YouTube that really show step by step what needs to be done.
Thanks for the feedback, Jeremiah38! I would be very grateful if you could share one or two links. Since you mentioned patience yourself: In your experience, are there any particularly common problems or steps where many people get stuck? Or is it more an individual issue?
lochen schrieb:
Many users have trouble correctly inserting the so-called dowels in the BILLY shelf unit
That sounds like a truly relevant problem to me, especially without instructions. In your opinion, is the correct placement of the dowels critical for the stability or more of a secondary issue?
JEREMIAH38
28 Mar 2018 14:11
Papeda schrieb:
Are there, in your experience, any particularly common problems or steps where many people get stuck?
Yes, this is often missing in tutorials: Many people underestimate the correct sequence, especially installing the back panel early enough. If the back panel is added too late, the shelving unit becomes unstable and you have to take everything apart again.
Also, the small dowels need to be inserted correctly. If they are crooked, the shelf supports won’t fit properly, which results in uneven shelves.
Here are two videos I find helpful:
1) https://www.youtube.com/watch?v=fakevideo1
2) https://www.youtube.com/watch?v=fakevideo2
I hope this helps you 🙂
