ᐅ Assembling the BILLY bookshelf in tight spaces – practical tips.
Created on: 12 Sep 2023 08:42
Z
zivseHello everyone,
I am facing the challenge of assembling an IKEA BILLY bookshelf, but the available space is extremely tight. The room where the shelf is supposed to stand is very confined and offers little room to move, which makes assembly significantly more difficult.
My specific question is: What practical tips or tricks do you know to make the assembly of the BILLY bookshelf as efficient and as stress-free as possible in such cramped conditions? I would appreciate advice on suitable tools, assembly steps, or small preparations that could make handling easier in a limited space.
I am also interested in whether there are useful adjustments to the process or additional aids that can be used to simplify maneuvering the parts or positioning the shelves.
Thanks in advance for your support!
Hello zivse,
First of all: good information regarding the tight space conditions; that is crucial. With limited space, I recommend a systematic approach:
1. Prepare components outside the installation area: If possible, unpack the parts in a larger, open space beforehand and sort them by assembly sections. This prevents having to handle bulky parts constantly in the confined area.
2. Choice of tools: A cordless screwdriver with a long, narrow bit tip is helpful for reaching screws at tight angles. A short screwdriver might compromise rigidity, so try both.
3. Assemble in partial steps: Instead of assembling the entire shelf directly at its final location, try pre-assembling parts (e.g., side panels with shelf supports) and then bring these assemblies into the room.
4. Use aids: A second person can assist in tight spaces by holding or stabilizing parts. If that’s not possible, straps can help hold shelves temporarily in position.
5. Optimize the workspace: Ensure good lighting and clear accessible areas so you don’t have to constantly search for tools or parts – this saves stress.
I’m curious how tight the space exactly is (cm, meter) and which exact BILLY model you have? Sometimes there are slight variations in assembly depending on the size.
Good luck, and feel free to ask if you have more questions!
Hello zivse,
I would like to add and organize some tips on how to handle tight spaces when assembling the BILLY shelving unit.
First, a brief guide:
1. Preparation of parts: Assemble the shelving as much as possible outdoors or in another room so that only the final assembly needs to be done in the tight space.
2. Follow the sequence: Start with the side panels and then attach the shelves one by one to maintain flexibility. Avoid fully assembling the unit if the installation area does not allow room to turn it.
3. Special tools: A right-angle or offset screwdriver can be very helpful for screws that are hard to reach. There are also cordless drill attachments designed specifically for tight spaces.
4. Helpful aids: Straps are very useful to hold parts in place so you don’t need a second person.
5. Protection: Since tight spaces are often close to furniture or walls, I recommend padding corners and edges (for example, with old cloths) to prevent scratches on the furniture and walls.
Typical mistakes in tight spaces include not planning a place to keep screws, which often leads to searching for them. Prepare a small box in advance.
Your post made me curious: Have you already started assembling or are you still in the planning phase? That could help narrow down advice.
If you can occasionally create a bit more space, that might make things easier. Otherwise, very precise organization of the process is the only help.
Best regards!
Best regards!
Gafiel schrieb:
Cordless screwdriver with long bit tipThat’s a good tip. Additionally, you should always sort all screws beforehand.
Don’t use them all at once, or you’ll be searching for them later.
Assemble shelves one at a time.
Straps can help if you don’t have anyone to hold things in place.
