Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
Bookstar
14 Jan 2020 20:53
Why don’t you install a stainless steel tray on the flat roof? That way, you would be worry-free forever. This way, there’s no fear of poor workmanship or leaks after 20 years.
Baufie
14 Jan 2020 20:56
You are using the same materials as we are on the flat roof.
What I don’t understand, however, is your construction method...
What material are you using as parapet capping?
rick201814 Jan 2020 21:21
@Bookstar Some of the roofs are being greened. The team is doing a good job. There is at least double the standard safety everywhere, and drains are installed. This is waterproof concrete. Even without additional waterproofing, we probably wouldn’t experience water entering the house anymore.
@Baufie We will also have a ventilated facade made of aluminum CuBond. We are extending this over the parapets on the various roofs. Only photovoltaic panels will be installed on the top roof (shown in the picture). The rest will be greened. The garage roof will have deep green roofing to the extent that bushes could be planted there... What part of the construction is unclear to you? Maybe I forgot something or didn’t explain it clearly enough.
Baufie
14 Jan 2020 21:27
I meant your statement, "double seals are already installed underneath"...
rick201814 Jan 2020 21:42
- Coating (EMAILLIT BV express)
- Elephant skin
- Baudertec
- Insulation boards
- Baudertec
- Tapered insulation boards
- Baudertec
- 2nd layer of Baudertec
- Final layer (not sure of the exact name but it is root-resistant)
I hope I’ve listed everything correctly. The parapet is also sealed multiple times, partly visible in the picture. Since the facade continues above it, this part is not directly exposed to weather.
On the green roofs, there will also be a geotextile, drainage layer, substrate, etc.
Baufie
14 Jan 2020 22:19
We have a tapered insulation layer, so one layer less.
The final covering is the Bauder Smaragd.
