Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
rick201814 Jan 2020 23:35
Even a double layer of Baudertec? I thought that wasn’t usually done.
Baufie
15 Jan 2020 00:14
rick2018 schrieb:
Even double layers of Baudertec? I thought that’s not usually done.
No, just a single layer.
All work done by ourselves.
guckuck2
15 Jan 2020 06:18
The top layer is always double. Or which one do you mean @rick2018?
rick201815 Jan 2020 06:26
Yes, the layer before the final covering. Bauder itself specifies only one layer before the final covering. So it doesn't always seem to be double.
guckuck2
15 Jan 2020 06:34
Hmm, I consider that normal and even necessary since the top layer serves as the actual waterproofing layer. Without vegetation, it is also the layer exposed to the weather.
The layers below seem a bit excessive to me. In addition to the emergency waterproofing, an additional sealing primer, and also a membrane between the insulation and the tapered insulation? For what purpose? Is the insulation sensitive to water, requiring extra protection against water infiltration?
Especially since, as you mentioned, waterproof concrete was used. The only real issue is the penetrations. The roof itself will not allow water to pass through the surface for the next 100 years.
Some even pour the parapet in one step together with the slab to avoid any joint that could cause problems.
Two rules for flat roofs:
1) never use wood
2) never use mineral wool insulation.
Baufie
15 Jan 2020 06:40
rick2018 schrieb:
Yes, the layer before the final covering. Bauder itself specifies only one layer before the final covering. So it doesn’t always seem to be applied twice.
The typical structure is as follows:
- Primer coat
- Vapor barrier membrane
- Insulation
- Cold self-adhesive membrane (here the KSA)
- Bitumen torch-on membrane
Why @rick2018 applied the KSA layer twice, I have no idea.
