Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Now a bit about me:
As Rick already mentioned, having 5 network outlets is the bare minimum. These network outlets are not related to home automation or KNX systems. They are solely intended to distribute internet throughout your house and enable data exchange between your devices at home.
There is usually a central point in the house, often in the utility room, where all the cables terminate and where the technical equipment is installed. You then need to decide whether everything should go into a network cabinet, multimedia distribution box, or simply be mounted on the wall. Each network outlet should be installed as a double socket and connected with 2 patch cables. To maintain flexibility for the future, the cables should be laid inside conduits so they can be replaced if needed. There should be at least one double socket per room. For rooms where more connections might be required—like the living room or office—of course, more sockets are necessary. Don’t forget the hobby room and garage. This setup is for fixed devices only. For Wi-Fi, plan at least one access point per floor. Whether this is sufficient depends on the floor plan. I prefer access points installed on the ceiling or at least high up on the wall. An outdoor access point for the patio and garden is often overlooked.
You might want to start a new thread on this topic.
Rumbi441 schrieb:
cat7 and the Fritzbox will probably do the jobYes, the Fritzbox works perfectly for most people in a home setting. A bit of Wi-Fi, connecting TV and PlayStation by cable... done. It’s hard to imagine in an online forum, but many households don’t even have a PC.Anyway, if the Fritzbox isn’t enough, you can always install additional switches, access points, and so on.
But that only works if you weren’t too stingy with network outlets!
So yes, run cables to every room, plan for access points on the ceiling, and lay the cables accordingly. Very important.
GeradeSchräg2 Oct 2021 10:42@rick2018
Since I haven’t found any really useful information, could you give me a rough idea of the price per m² (square meter)?
rick2018 schrieb:
In the bathrooms, we used a seamless system from the company Dold. The joint between floor and wall is sealed with PU sealant.
I need to go back to the topic of the poured asphalt, or more precisely, the copper pipes.
We are also planning to use a similar type of floor, but our underfloor heating specialist strongly advises against it because he no longer wants to install copper. The reason is that copper is more prone to corrosion and, generally, it’s not common practice anymore. For this reason, he wants to install standard screed and then lay parquet or vinyl on top, which is obviously not what we want.
In short, the question for Rick: Which copper alloy did you use?
