Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Now a bit about me:
I can't tell you the exact alloy from memory. But it sounds like your underfloor heating specialist has no knowledge or experience with mastic asphalt. That's why they want to go with a traditional approach. Get a specialist involved, and then there won’t be any problems.
Please keep in mind that anything in contact with mastic asphalt must withstand at least 250°C (480°F). Grinding produces a lot of dust even when suction is used. So, above all, do other work first and then protect the floor...
Under no circumstances should the floor be sanded after applying filler, painting, etc. When using the machines, you must sand right up to the edge. There will always be some marks. The dust tends to stick to the wall paint even if the area is covered with plastic sheets. Floor-to-ceiling windows should also not be installed yet due to the heat.
In terms of planning and process, poured asphalt is considerably more complex than traditional methods.
A layer of insulating material was applied to level and cover the surface. It consists of small beads. I don’t have the exact term for it.
This will then be covered, and the underfloor heating will be installed on top. In the case of screed asphalt, the installation spacing is different (larger) because it conducts heat very well, is highly flexible, and the underfloor heating is located within the final floor covering.
Therefore, it is essential to hire a specialist who is experienced with this type of installation.
