ᐅ Bathroom Lighting: Recessed Spotlights or Central Ceiling Fixture?
Created on: 27 Dec 2025 20:19
Astrid74
I am currently planning the lighting for my bathroom and could really use your advice.
The mirror lighting is already decided, but now I need to consider whether to add recessed ceiling spotlights or a central ceiling light.
My questions:
  • Which option is more practical for providing even lighting in the bathroom?
  • Are there specific placements or tips you would recommend?
  • What should be considered when combining these with fixed mirror lighting?
I would really appreciate your experiences or suggestions!
Thank you in advance!
Draufsicht 3D-Bad mit Dusche, Badewanne und Doppelwaschbecken in modernem Design.
3D Badezimmer-Render mit Badewanne, rosa Mosaikfliesen und grauen Wandfliesen
wiltshire
27 Dec 2025 23:54
Also an argument in favor of a centrally located ceiling light. For functional lighting in the bathroom, I would choose around 4000K, and for cozy lighting 3000K or less. Pay attention to a high CRI in the bathroom – this ensures colors are rendered especially true to life. For people who work with make-up, this is a huge comfort improvement. Good lighting around the round mirror is available from several manufacturers – we have installed a model from Agape.
nordanney
28 Dec 2025 12:47
If the ceiling is slightly lowered, you could also consider using 4 spotlights with a 270-degree beam angle.
Otherwise, the same as the previous answers.
wiltshire
29 Dec 2025 18:22
nordanney schrieb:
If the ceiling is slightly dropped, you could also consider 4 spotlights with a 270-degree beam angle.
What do those look like? From 180 degrees, they actually illuminate behind their mounting plane.
Stefan67422578
2 Jan 2026 11:23
It depends on what you expect from the lighting. For simple brightness, a central ceiling light is enough.
Personally, I have 4 spotlights arranged in a square in the guest bathroom. This also provides good brightness and a clean look. I always find it difficult to find attractive lamps. However, it is not very cozy.
I would probably go with the 4 spotlights again for brightness, but also consider adding indirect lighting. Wall lights, pendant lights, or a light cove.
motorradsilke
2 Jan 2026 11:34
We have a ceiling light with adjustable color temperatures. It can be set from bright to warm.
2 Jan 2026 12:14
A dimmer also creates a cozy atmosphere.
