ᐅ Are there sustainable cleaning products suitable for Ikea HEMNES furniture?
Created on: 24 Sep 2022 09:37
Janburkard
Janburkard
24 Sep 2022 09:37
I recently bought some Ikea Hemnes furniture and noticed that the surfaces are very sensitive to conventional cleaning products. Since I place great value on sustainability, I’m wondering: Are there truly sustainable cleaning products specifically suitable for caring for and cleaning Hemnes furniture?
It’s important to me that the product does not contain aggressive chemicals that could damage the surface, nor that it is harmful to the environment or problematic in terms of production and disposal. Ideally, it should also be free from synthetic fragrances and colorants.
Do you have experience with such products, maybe even DIY solutions, that work well and at the same time help maintain the durability of Hemnes furniture? I’m looking forward to concrete tips and also background information on why these products are considered sustainable. Thanks in advance!
Hector
24 Sep 2022 11:02
Janburkard schrieb:
Are there really sustainable cleaning products that are specifically suitable for the care and cleaning of HEMNES furniture?
That’s an interesting question, but I think it’s important to separate a few different aspects: on one hand, material compatibility with painted or oiled wooden furniture, and on the other hand, the ecological sustainability of the cleaning product itself.
Many so-called “sustainable” products use plant-based surfactants and avoid harsh solvents, but these can sometimes damage water or oil films that protect the surface.
Therefore, I recommend especially comparing technical data sheets and also consulting reviews from other buyers who clean HEMNES furniture—with its light, often painted surfaces. Sustainability should not come at the expense of the furniture’s integrity, as that can lead to more effort over time.
How exactly do you define sustainability for cleaning products in this context? Just environmental standards, ingredients, or also product origin and packaging?
lalutau
25 Sep 2022 14:46
A clear and helpful clarification. The term sustainability is often used vaguely, especially when it comes to cleaning products.
Regarding Ikea HEMNES furniture, which is typically made from solid pine wood with a lacquer or white painted finish, the compatibility of ingredients is crucial.
I would like to list some criteria that a sustainable cleaning product for this type of furniture should meet:
- Biodegradable ingredients without microplastics
- Free from phosphates, strong acids, or bases
- No synthetic fragrances or colorants
- Packaging made from recycled or easily recyclable materials
- Manufactured according to ecological standards (e.g., without palm oil or with fair labor conditions)
Specific products often contain low concentrations of sodium hydroxide, but vinegar-based solutions should be avoided due to their acidity, which can damage the lacquer finish.
DIY solutions using mild, pH-neutral soapy water and a soft microfiber cloth are often the gentlest and also support sustainability by reducing packaging waste. For tougher stains, waxes or special furniture oils without solvents may be suitable if the surface is oiled – however, HEMNES furniture is usually lacquered.
An important tip: wiping immediately with clean water after cleaning helps prevent premature aging of the surface.
Ethan
26 Sep 2022 07:23
Janburkard schrieb:
Do you have experience with such products, maybe even DIY solutions, that work well and at the same time support the durability of HEMNES furniture?
I would like to add the following: For Ikea HEMNES furniture, I often recommend a combination of simple, sustainable home remedies that are gentle and effective.
- The standard cleaning method is lukewarm water with a drop of mild, plant-based dish soap, applied with a soft cloth.
- For occasional maintenance, natural oils like linseed oil can be used, provided the furniture surface is oiled. Since HEMNES is usually lacquered, oil treatments should be applied sparingly and according to the manufacturer’s instructions.
- Avoid harsh cleaners or abrasive materials, even if they are advertised as biodegradable, as they can damage the lacquer finish.
If you prefer a purchased product, look for certifications such as the Blue Angel or Ecocert, which at least guarantee minimum standards for ingredients and environmental compatibility.
If desired, I can also name a few specific products I have personally tested for sustainable furniture care.
All in all: Sustainable cleaning, especially for HEMNES furniture, means being cautious with ingredients and applying treatments gently to preserve the surface over time.
