ᐅ Are there specific IKEA Metod solutions designed for small bathrooms?
Created on: 31 Aug 2020 09:12
roemil
roemil
31 Aug 2020 09:12
Good morning everyone,
I am currently planning the renovation of my small bathroom (about 3.5 m² (38 sq ft)) and am very interested in using IKEA METOD kitchen cabinets as a storage solution. Are there specific METOD modules or options that work particularly well for small bathrooms? I am especially curious whether the kitchen cabinets can be adapted to meet the special requirements of a bathroom, for example in terms of moisture protection, storage for bathroom items, or smart solutions for compact layouts.
I have read quite a bit but am unsure whether METOD is generally suitable or whether it might be better to use the BADILEN series or other IKEA furniture instead. Perhaps someone here has practical experience or tips on how to use METOD effectively in a bathroom? It would be great if you could also mention any necessary modifications.
Thank you in advance!
O
onMarcos
31 Aug 2020 09:37
Hello roemil,
Since you specifically asked about METOD solutions for a small bathroom, here are a few important points that might help you with your planning:
- METOD is primarily a kitchen system, known for its modular and flexible components. Compared to traditional bathroom furniture, its moisture resistance is limited.
- For small bathrooms, wall cabinets and base cabinets in narrow widths (e.g., 20 or 40 cm (8 or 16 inches)) are more suitable. METOD offers exactly these sizes, which create valuable storage space without taking up much room.
- Important: The cabinet carcass and fronts should be protected with suitable impregnations or water-repellent foils, as METOD is not inherently as moisture-resistant as BADILEN or other bathroom furniture.
- The selection of drawer systems and organizers for cutlery and utensils can be adapted well for bathroom organization.
- One advantage of METOD is the option to choose worktops made of water-resistant materials (e.g., available through IKEA or custom options), which can be used as vanity tops.
Summary: METOD can be used in a small bathroom if moisture protection is considered and compact modules are selected. For small layouts, the variety of sizes and interior organization options is very helpful.
If you want, I can also provide tips on how to properly impregnate the furniture or suggest alternative options.
maunau70
31 Aug 2020 10:05
I would say: METOD is rather secondary for the bathroom. It’s better to use the BADILEN series or other furniture specifically designed for wet rooms.
If you really want to use METOD, then only with protective lacquer and make sure to plan for good ventilation.
Matthewt48
31 Aug 2020 11:29
Hello roemil,
I can understand why you’re interested in METOD as a kitchen system, since its modularity is really excellent. To answer your question in detail:
1. Moisture resistance: METOD is not originally designed for bathrooms. However, you can still use it if you treat the furniture surfaces or apply water-repellent coatings. This works better in small, well-ventilated bathrooms.
2. Sizes: The wide range of METOD sizes is very suitable for small bathrooms. In addition to wider cabinets, there are also 15 cm (6 inches) wide base cabinets that take up very little space.
3. Combination with bathroom furniture: You can easily combine METOD with BADILEN or other bathroom series, for example using METOD for storage and BADILEN for the washbasin unit.
4. Countertops: IKEA also offers water-resistant countertops made of plastic or stone-look materials, which you can use as a washbasin surface.
My advice: Consider whether you can apply waterproof coatings specifically for wet areas and ensure good ventilation. Then METOD is an affordable and flexible solution.
If you like, I can later provide more information about recommended countertop sizes and combinations.
Gilbert
31 Aug 2020 12:44
I rather believe that IKEA does not offer well-thought-out solutions for small bathrooms at all. METOD is a kitchen system, and even if you repurpose it, it won’t really provide a perfect solution for the bathroom.
roemil schrieb:
I’m mainly interested in whether the kitchen modules can be adapted to meet the special requirements of a bathroom, such as moisture protection
These simply don’t go together; you can somehow squeeze the stuff in, but it's more of a makeshift solution than a practical one.
I would rather say: it’s better to choose a bathroom solution that is truly designed by the manufacturer for wet rooms, so you can enjoy it for a long time.
refinar
31 Aug 2020 13:18
I would like to add a few points, as some aspects have already been well explained by onMarcos and Matthewt48.
Regarding the customization of METOD modules for the bathroom:
- The flexible interior design of METOD is a major advantage; you can use drawers with dividers to neatly organize towels, cosmetics, or cleaning products.
- To improve moisture protection, I recommend sealing all edges with water-resistant tape and sealing the narrow gaps between walls and cabinets.
- Installing legs with some height allows better air circulation under the cabinet, which helps prevent mold.
- Additionally, METOD is very suitable if you want to build around radiators or pipes, as the modules can be easily adjusted and resized.
Conclusion: If you are careful during installation, you can create well-fitting, custom storage solutions with METOD in a small bathroom that are more affordable than typical bathroom furniture. Just don’t underestimate the moisture issue.
