ᐅ Are there replacement handles for Malm dressers available in other colors?
Created on: 12 Aug 2024 09:42
Nobo46
Nobo46
12 Aug 2024 09:42
I have a somewhat specific question that might also interest several users of IKEA Malm dressers: Are there replacement handles for IKEA Malm dressers available in colors other than the originals? Specifically, I am looking for options in different colors – for example, black, gold-toned, or even in vibrant shades – to make the dresser a bit more unique and modern.
I’m not interested in wooden handles, but would prefer handles made of metal or plastic that are easy to replace. Does anyone know reliable sources or manufacturers that offer these? If so, how is the compatibility regarding drill spacing and mounting?
Do you see this more as a DIY project, or can suitable parts be found commercially? I’m looking forward to your experiences and tips!
SETHBLA
12 Aug 2024 10:05
Yes, replacement handles are available for Malm dressers in various colors. Online stores such as Amazon or eBay offer many compatible handles. Pay attention to the drill hole spacing, which is usually 128 mm (5 inches). Metal and plastic handles are widely available.
gregto
12 Aug 2024 12:26
SETHBLA schrieb:
Yes, there are replacement handles for Malm dressers available in various colors.
I would like to add exactly this: IKEA typically uses handles for Malm dressers with a standard drill hole spacing of 128 mm (5 inches), which is important for compatibility.
There are many third-party suppliers, especially on platforms like Etsy or specialty furniture accessory shops, offering both metal and plastic handles in a wide range of colors, including matte black, gold-tone, or colorful options for personalized accents.
For those with DIY experience who want to improve this even further: handles can also be painted or modified, but this requires some craftsmanship skills, particularly to ensure the surface finish remains durable.
When choosing handles, be sure to pay attention to the projection and design to avoid handles that look too bulky or visually out of place. Additionally, some handles have different mounting methods, which might complicate the replacement.
tra_nina
12 Aug 2024 15:03
From a technical perspective, it is crucial to pay close attention to the exact drill hole distance when selecting replacement handles for Malm dressers; as mentioned, this is typically 128 mm (5 inches).
Various manufacturers offer replacement handles in different finishes, including anodized aluminum, painted steel, or high-quality plastic. The color options range from classic black and white to popular copper or brass tones.
Online retailers are increasingly specializing in customized solutions, often providing detailed product descriptions regarding dimensions and installation.
It is essential to check the screw length and diameter, as an ill-fitting handle may not sit properly or can loosen over time.
Due to the widespread use of the Malm series, the market for compatible replacement parts is reliable, but it is advisable to review customer feedback confirming the fit.
flo-Theres
13 Aug 2024 08:51
gregto schrieb:
you can also paint or modify handles yourself
This is an important point, especially since inexpensive metal handles can be relatively easily changed to different colors using powder coating or spray paint.
It is crucial to use a good primer and paint designed for metal to ensure durability and appearance.
If you are interested in colorful plastic handles, make sure they are UV-resistant so the color does not fade quickly in sun-exposed rooms.
In general, I recommend testing on sample pieces first when painting handles yourself to check the desired result.
For modern and elegant options, stainless steel handles with a brushed finish or black coating provide a professional look that complements the Malm dresser well and is long-lasting.
Nobo46
13 Aug 2024 10:37
tra_nina schrieb:
You should definitely check the length and diameter of the screws
Thanks for the important tip! I actually measured, and the drill holes are about 128 mm (5 inches), but the screws are still relatively short. I will pay special attention to this when ordering replacement handles.
flo-Theres schrieb:
Powder coating or spray paint can be relatively easily changed to different colors
That sounds interesting. I’m actually leaning more towards a pre-finished handle but want to keep the option open if the selection is really too limited.
I will now specifically search on Etsy and Amazon for black and gold metal handles and check the reviews—thanks for the tips! If anyone has any specific links or shops they recommend, please share. 🙂
