ᐅ Are there more durable alternatives to MALM coatings?
Created on: 29 Jan 2020 14:37
guilherme
guilherme
29 Jan 2020 14:37
I am currently looking into whether there are more durable alternatives to Malm finishes. Malm surfaces are known for offering limited protection against scratches, wear, and moisture, especially on furniture made from particleboard. I’m particularly interested in coating technologies or materials that are significantly more resistant without drastically increasing the price.
Perhaps someone is familiar with innovative methods that have proven effective in everyday use or can share experiences with long-lasting furniture coatings. I am specifically searching for alternatives that are sturdy enough to avoid noticeable signs of wear after just a few years.
I look forward to your opinions, tips, and also critical evaluations. Thank you!
naujon
29 Jan 2020 15:09
Hello guilherme,
regarding your question about more durable alternatives to MALM coatings, I would like to share a few options based on my experience and various sources.
1. Painted surfaces: Unlike thin film coatings like those used on MALM, multi-layer applied paints (e.g., two-component paints) provide a very strong protective layer. They are much more resistant to scratches and moisture, although the additional cost and repair effort are higher.
2. Melamine resin coatings: These are thicker and harder than conventional films and are often used on higher-quality furniture. They offer significantly better abrasion resistance and scratch protection. Compared to MALM, a thicker substrate board is usually used here.
3. CPL (Continuous Pressure Laminate): This is one of the most durable surfaces, applied under high pressure and heat. The surface is extremely resistant to scratches, heat, and moisture.
A common mistake I see is trying to get a perfect surface at the lowest possible cost: this reduces durability. So if you are looking for longevity, you should focus on materials and processing methods that involve higher manufacturing costs.
If you need more details about the processing or specific coating types, please let me know.
PLOMA
30 Jan 2020 09:18
Hello guilherme and everyone interested,
naujon schrieb:
Unlike MALM, a thicker substrate board is usually used here.
This is an important point because the substrate board significantly affects durability. MALM furniture, which often consists of thinner particle boards with foil coating, is generally more susceptible to mechanical and environmental stresses.
From a technical perspective, there are multi-layer coating processes that use UV curing and are much more resistant. Several layers are applied and cured with UV light, resulting in a highly durable surface. These methods are commonly used for high-quality office furniture or kitchen fronts.
Another alternative is using real wood surfaces with a high-quality sealant. The natural surface is more resistant, but for furniture that is heavily used, it is important to have good sealing that protects against water, grease, and abrasion.
May I ask what exactly your application is? Is it for residential furniture, office furniture, or specific requirements (e.g. wet rooms), so that it is easier to assess which alternative is truly suitable?
leguson
30 Jan 2020 11:25
For longer durability than MALM coatings, I recommend CPL laminate. It is sturdy, scratch-resistant, and moisture-resistant.
Alternatively, you can opt for lacquered surfaces, which are less prone to damage and easy to repair.
U
usbla
1 Feb 2020 18:42
Regarding durable alternatives to MALM coatings, the following can be added:
PLOMA schrieb:
multi-layer paint processes that use UV curing and are significantly more resistant.
UV-cured paints indeed offer excellent resistance to scratches, chemicals, and moisture. These finishes are commonly used in the furniture industry when long-term use and a high-quality appearance are important.
A sustainable alternative would also be HPL surfaces (High Pressure Laminate), which are produced similarly to CPL but are slightly thicker and more durable. They are resistant to mechanical impacts and thermal stresses.
In terms of price, UV paint and HPL are usually considerably more expensive than the simple foil coatings used on MALM. Therefore, the intended use must be clearly defined. For furniture in heavily used areas, the additional cost is often justified.
The best solution depends on balancing cost, appearance, feel, and durability. For worktops or furniture in frequently used rooms, my recommendation is clearly CPL or UV paint coatings.
Are environmental aspects also considered in your case? There are, for example, ecological paints that are still durable.
