ᐅ Are there any modifications to make IKEA PLATSA more space-efficient?
Created on: 8 Jun 2020 13:27
FUFLO
FUFLO
8 Jun 2020 13:27
I am currently using IKEA Platsa as a storage solution, but I am looking for ways to make the modules more space-efficient without limiting their practical use. Specifically, I am interested in whether there are modifications, conversions, or alternative installation methods that can help optimize storage capacity while reducing footprint. I am thinking of smart connection or storage systems, interior layout adjustments, or special built-in techniques that provide more flexibility or save space. Your experience and tips would be greatly appreciated, especially if you know of any DIY adaptations or proven tricks to use Platsa more effectively. Thanks in advance!
Nigel
8 Jun 2020 13:54
I have partially screwed my PLATSA units together vertically, which makes better use of the height.
Additionally, shelf boards can be replaced with thinner panels to gain a few centimeters (inches) of extra interior space.
Nadine
8 Jun 2020 14:33
Hello FUFLO,
your question is very well formulated because it focuses on practical solutions. Many users combine PLATSA elements by arranging them in 90-degree corners, which often avoids unused corner spaces and thus provides more storage in the corner.
Another tip is to use drawer inserts inside the modules – this helps organize storage better and prevents empty spaces that would otherwise be wasted. Using custom-cut compartments made from thinner material can also be helpful.
If you are not satisfied with the standard dimensions, some people remove the back panel and screw the modules directly to the wall, allowing installation under sloped ceilings or roof inclines, which makes better use of the floor area.
I hope this helps you a bit. If you have any specific tight spots, feel free to ask again.
FEKAU
9 Jun 2020 09:18
A space-saving modification for IKEA PLATSA is combining open and closed modules to create not only storage but also usable surfaces, for example as a bench or shelf space.
Additionally, the following approaches are recommended:
- Removing the back panels of modules to allow more flexible installation options, especially for corners and niches.
- Using Plexiglas instead of solid wood for shelves, which reduces weight and slightly increases the interior space.
- Using shelves with adjustable heights to customize the space according to the size of individual items.
- Mounting to walls with special angle brackets to position the cabinet closer to the wall or into tight spaces.
These measures are based on the material properties and installation flexibility of PLATSA and enable optimized use of space without changing the character of the system.
FELOTAU
9 Jun 2020 11:44
I can clearly understand how frustrating it can be when space is limited and you want to get more out of the PLATSA system. There are many DIY modifications, but sometimes it can be a bit challenging since the modules cannot easily be reconfigured without damaging the system.
Nigel schrieb:
I have partially screwed my PLATSA elements together vertically, which makes better use of the height.
I find this tip very helpful because ceiling height is often underutilized. I have also heard from others that reusing removed shelves as intermediate dividers inside the modules helps keep things more organized.
In conversations with friends, it also came out that it makes sense to mix different compartment sizes, creating small sections for odds and ends that would otherwise get lost. This can save a lot of space and make tidying up easier, especially in small apartments.
RENMA
10 Jun 2020 08:53
In addition to the previously mentioned modifications, I can provide some technical details:
The PLATSA system is based on standardized height and width dimensions with a 20cm (8-inch) grid. To save space, an important modification approach is to reduce the depth of the modules. This can be achieved by:
- Shortening the side panels or back panels (be careful with stability!)
- Using alternative back panels made of thinner materials
I also recommend the targeted use of integrated sliding doors, which require little clearance in front of the furniture and free up more usable space compared to hinged doors.
Finally, custom-made drawer inserts improve storage space by precisely utilizing the interior dimensions.
However, these modifications require craftsmanship skills and appropriate tools.
