ᐅ Are there any known issues or common problems with the IKEA Hemnes wardrobe?
Created on: 17 Feb 2024 19:36
bojan10Hello everyone, I registered here because I am currently considering the IKEA Hemnes wardrobe and want to take a closer look at potential weak points of this model. Specifically, I’m interested in whether there are any known issues based on user or assembly experiences that you should particularly watch out for during construction or everyday use. Are there typical areas that wear out faster or where stability tends to decrease? Or are there technical details often overlooked that might cause problems later on? I would really appreciate detailed assessments, as I value not only the design but also durability and functionality.
This is a clear and precise question. Based on my experience with the IKEA Hemnes wardrobe, there are two areas that are often criticized:
- The back panel is relatively thin and is attached with small nails. This can lead to the back panel coming loose with frequent use or when moving the wardrobe.
- The door hinges seem sturdy, but over time and with frequent use, small gaps can develop, causing a slight rattling noise.
When assembling, I recommend attaching the back panel carefully and with attention, possibly using additional screws or stronger fasteners if possible. Also, the doors should be well adjusted after assembly. This helps reduce future issues with fit and alignment.
lyndon schrieb:
The back panel is relatively thin and is attached with small nails.I can confirm this observation. The thin back panel is a common weak point in many affordable furniture pieces, including the Hemnes. If stability is important, it is advisable to reinforce the back panel after assembly with thin battens or, if the material allows, to use stronger screws.
lyndon schrieb:
The door hinges seem sturdy, but with frequent use, small play can develop over time.Additionally, it is common for the hinge adjustment to loosen slightly over time. A small readjustment effort over the years is therefore quite normal. Overall, the cabinet is fairly solid for the price, but it is wise to proactively address the known weak points.
warrenka5718 Feb 2024 12:02I noticed that the shelves in the Hemnes wardrobe can sometimes seem a bit thin and may bend under heavier loads. This initially surprised me a little, as you need to carefully estimate the weight to avoid any issues.
Still, I find the wardrobe quite satisfactory overall; you just need to know what to watch out for. If you enjoy DIY, you can reinforce certain areas or add sliders to both extend its lifespan and make using it more comfortable.
Have you already decided exactly where the wardrobe will be placed in your room? Sometimes location factors, such as humidity or uneven flooring, can also affect stability.
warrenka57 schrieb:
Have you already checked exactly where the wardrobe will be placed in your room?Good question – yes, the planned location is a bedroom with relatively stable humidity and a very level floor (parquet). I think the environment is comparatively ideal for solid wood pieces, even though the Hemnes is more of a combination with engineered wood panels.
lyndon schrieb:
The back panel is relatively thin and is attached with small nails. This can lead to the back panel coming apart with frequent stress or when moving it.Thanks for this advice. That does indeed sound like a weak point that I will probably reinforce.
pikin schrieb:
A little adjustment effort over the years is practically normal.I also take note that at least the hinges should be checked from time to time. That is helpful for long-term maintenance. Overall, I have the impression that the model can be used very satisfactorily with some effort. Does anyone else have comments on the quality of the fittings or the surface finish? I am interested to know if scratches or signs of wear are often a problem there.
bojan10 schrieb:
Does anyone else have comments regarding the quality of the fittings used or the surface finish?The fittings on the Hemnes are generally decent, especially considering the price. The metal parts (hinges, screws) are either galvanized or chrome-plated, which helps protect against rust. However, I recommend checking the fittings occasionally, particularly in more humid environments, and lubricating them if necessary.
Regarding the surface: the white paint finish is generally durable but can be vulnerable to sharp objects or edges. Small scratches can occur easily but can usually be repaired with special wood surface repair kits.
If you want to maintain a long-lasting appearance, I would suggest handling the furniture carefully—for example, avoid placing heavy or sharp-edged objects directly on the surfaces.
